Microsoft Releases Cumulative Update 16 (CU16) for Management Reporter
  • Microsoft Releases Cumulative Update 16 (CU16) for Management Reporter
    Posted by Noah Moseley on March 3, 2017 at 11:06 am
    • Noah Moseley
      March 3, 2017 at 11:06 AM
      Downloads are now available on CustomerSource and PartnerSource for Management Reporter Cumulative Update 16 (CU 16). This release lists the following fixes:
      Issues fixed in Management Reporter 2012
      Cumulative Update 16 (CU16) 2.12.16000.17
      Last modified February 24, 2017
      Microsoft Dynamics Bug ID 3749486
      Change tracking only gets enabled on the first Microsoft Dynamics GP company database
      Microsoft Dynamics Bug ID 3751976
      Wildcards and ranges doesn’t return all valid dimension combinations
      Microsoft Dynamics Bug ID 3753112
      Dimension filter uses an OR condition instead of an AND in different scenarios when two dimensions are
      specified
      Microsoft Dynamics Bug ID 3754945
      Dynamics GP: Management Reporter is performing a count query before actual query, doubling the query
      cost with data mart
      Microsoft Dynamics Bug ID 3754947
      Dynamics GP: Management Reporter fact integration slow when posting large Analytical Accounting
      batches
      Microsoft Dynamics Bug ID 3754948
      Dynamics GP: GP data validation not working for Microsoft Dynamics GP 2016
      Microsoft Dynamics Bug ID 3755023
      Dimension filter uses an OR condition instead of an AND if using a dimension value that does not exist
      Microsoft Dynamics Bug ID 3757515
      Dynamics GP: Unable to create GP integration with GP 2016 Dexterity Shared Components
      Microsoft Dynamics Bug ID 3757516
      Dynamics GP: Yes/No Analytical Accounting dimension not working or integrating correctly in the
      Management Reporter data mart
      Microsoft Dynamics Bug ID 3767519
      Report generation fails when using a dimension value setting in the reporting tree based on MainAccount
      Microsoft Dynamics Bug ID 3768350
      Dynamics AX: Company Integration very slow when many records in SECURITYUSERROLECONDITION table
      Microsoft Dynamics Bug ID 3768609
      MR CU15 Known Issue – @DateLong AutoText header displays day of week in web viewer
      Microsoft Dynamics Bug ID 3771542
      Dynamics AX: Integration fails if collation is different between tempdb and Microsoft Dynamics AX
      database
      Microsoft Dynamics Bug ID 3778344
      Dynamics AX: Vendor name transaction attribute isn’t correct when using a virtual company with a shared
      table collection that includes VendTable
      Microsoft Dynamics Bug ID 3794033
      Report generation fails when there is a duplicated name for a dimension value
      Noah Moseley, Senior Consultant at the MSX Group
      Noah.Moseley@MSXGroup.com
      Email me if you need training or consulting services for Management Reporter, Forecaster or FRx.
      Management Reporter and Forecaster User Forums are March 14th and 15th
      http://www.msxgroup.com/user-forums
    Noah Moseley replied 9 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Microsoft Releases Cumulative Update 16 (CU16) for Management Reporter’ is closed to new replies.
