Management Reporter will not launch
Posted by Jennifer Erhard on August 19, 2019 at 1:23 pm-
D365 – I have tried to edit and create a new report both in Internet Explorer and in Chrome and Management ReportDesigner.Application never opens.Ā I have tried the clickonce in chrome.Ā All I get is nothing.Ā It will ask if I want to open ReportDesigner.ApplicaitonĀ I click yes.Ā It says it connecting but nothing ever opens.
I can loggon to my Manager’s computer and it opens just fine.Ā I can login at someone else’s computer that has security access and it does nothing as well.
I have verified I am running the .Net frame work that is correct.Ā We are up to date with software updates.Ā I have to be missing something but have tried everything that I could find on the web.Ā Anyone have any idea what I don’t have setup correctly on my computer.
#FinanceandOperations #managementReporter
Thank you for the help——————————
Jennifer Erhard
Senior Accounting/ERP Analyst
Kentucky Lottery Corporation
Hi Jennifer.
Maybe a pop-up blocker on your machine is stopping the window from opening. You might also have to add an exception for the 365 extension that is being blocked. I saw this article on LinkedIn.
https://www.linkedin.com/pulse/dynamics-365-error-starting-specific-applications-using-baumgarten/
Noah Moseley
Senior Partner/Consultant
MSX Group
Pensacola FL
And if using Internet Explorer, this has worked for me and clients also:
- Add the AX7/D365 site to Trusted Sites in IE (Internet Options | Security tab | Trusted sites)
- Set the Security to Medium-Low (Internet Options | Security tab | Trusted sites | Security level for this zone = Medium-low); Some time when MR OneClick app does not open we need to clean the cache by running:Ā rundll32 dfshim CleanOnlineAppCache?
Derek Krebs
Sr Consultant
MSX Group
derek.krebs@msxgroup.com
Corey Warawa
MemberAugust 20, 2019 at 10:00 AM
Hi Jennifer,I have experienced this many times when running MR or opening workflow configurations in different D365 environments.Ā Derek’s suggestion to clean the cache is the one that I have used for at least a couple years and it seems to work without fail.
Corey Warawa
Functional Architect
Liquor Stores North America
Edmonton AB
…and one other item to share that I had to do for another client:
Derek Krebs
Sr Consultant
MSX Group
Solomon Maricle
MemberAugust 21, 2019 at 12:03 PM
I had this occurring and in investigating, found it was throwing errors locally about required components missing.Ā You do mention ClickOnce, which I presume you’re referring to theĀ Meta4 ClickOnce Chrome extension?——————————
Solomon Maricle
Technical Solutions Architect
PAR Technology
Norwich NY
Thank you all for the suggestions.Ā I still haven’t had any success.Ā We have tried the statement to clear the cache.Ā I have also added the trusted sites and the other suggestions.Ā Anything else anyone has tried?
Jennifer Erhard
Thanks everyone.Ā Ended up needing Microsoft Package C++ installed on my machine.
Jennifer Erhard
Jennifer Erhard replied 6 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘Management Reporter will not launch’ is closed to new replies.
