Item coverage and ordering setups changing
  • Item coverage and ordering setups changing
    Posted by DSC Communities on January 31, 2017 at 3:58 pm
    • Seth Greenberg
      January 31, 2017 at 3:58 PM
      At times when I review the item coverage, the time fence, negative, and positive days, multiples, and/or MOQs have been adjusted to something that doesn’t make sense based on our coverage groups or known item setups. I am not sure if anyone can resolve without a live example. But I wanted to know if anyone else has had similar issues or if this sounds mostly like people changing things by mistake.
      Look forward to a reply.
      Best Regards,
      Seth
      Seth Greenberg
      Supply Chain Manager
      Hamamatsu Corporation
      Middlesex NJ
    • Andrew Lencsak
      March 14, 2017 at 2:17 PM
      Hi Seth, do you have any live examples or more information? There shouldn’t be anything standard that is changing them, so does sound like users adjusting them. Typically, most would suggest you don’t give end users access to the setup section of the modules except for key SMEs responsible for the configuration to avoid potential issues with users changing settings.
      Andrew Lencsak
      Senior Application Consultant
      eBECS US
      New Hampshire
The discussion ‘Item coverage and ordering setups changing’ is closed to new replies.
