Item coverage and ordering setups changing
  • Item coverage and ordering setups changing
    Posted by DSC Communities on February 10, 2017 at 9:03 pm
    • Seth Greenberg
      February 10, 2017 at 9:03 PM
      At times when I review the item coverage, the time fence, negative, and positive days, multiples, and/or MOQs have been adjusted to something that doesn’t make sense based on our coverage groups or known item setups. I am not sure if anyone can discuss without a live example. But I wanted to know if anyone else has had similar issues or if this sounds mostly like people changing things by mistake.
      Look forward to a reply.
      Best Regards,
      Seth
      Seth Greenberg
      Supply Chain Manager
      Hamamatsu Corporation
      Middlesex NJ
    • Dave Phillips
      February 13, 2017 at 9:10 AM
      Hi Seth –
      It sounds like people are changing Item Coverage values (or a customization is at work).
      One avenue you could use is the Dynamics AX database logging functionality to gather more information on what may be happening (Alerts might work too).
      A word of caution on Database Logging (and Alerts). Think twice (even 3x) before logging a table/field that sees a lot of updates or inserts such as ReqPO, ReqTrans, etc. (a couple of data sources in the MRP Planned Order form) because such logging will impact MRP run times and disk space. Also, never forget you have logging turned on and make a point to turn it off (or review use) at a future date.
      Thanks…..Dave
      Example of AX Database Logging on Negative Days update. Negative Days increased to 15 days.
      Dave Phillips
      MSFT Senior PFE
      Microsoft
      Fargo ND
    • Seth Greenberg
      February 15, 2017 at 3:35 PM
      Thank you, Dave.
      Seth Greenberg
      Middlesex NJ
The discussion ‘Item coverage and ordering setups changing’ is closed to new replies.
