Help Searching Customer Account Field 2012 RTM
  • Help Searching Customer Account Field 2012 RTM
    Posted by lholmes@hamamatsu.com on December 19, 2018 at 11:37 am
    • Lori Holmes
      December 19, 2018 at 11:37 AM
      Hello AXperts.Ā  I am befuddled and looking for help.
      AX 2012 RTM
      We have a user who cannot search on the Customer Account field after personalizing it into Sales and MarketingSales OrdersAll Sales Orders.
      CustomerAccount
      I can reproduce it under her account.Ā  I cannot reproduce it under my account using the same security as her.Ā  I have also deleted all.auc and .kti files and cleared all usage data.
      Anyone have a clue?
      Thanks!!!
      Lori Holmes
      Hamamatsu Corporation
      Bridgewater, NJ
    • Robert Harriman
      December 20, 2018 at 8:12 AM
      Hello Lori,
      When she personalizes her screen, does she pull in someone else’s saved personalization or add the fields manually?Ā
      I had something somewhat similar to deal with recently, the user could not see certain things such as the account number and customer name.
      She was using someone else’s saved personalization. I took the steps you mentioned above, deleted the shortcut to AX and pulled in the most recent shortcut.
      I then pulled in the columns and required fields one by one. This worked.Ā
      Hope this helps.
      Thanks – Rob
      Robert Harriman
      The Eastwood Company
      Pottstown PA
    • Lori Holmes
      December 21, 2018 at 12:04 PM
      Hi Robert…thank you for the reply.
      I can reproduce using a new personalization (after clearing usage data) and using an existing personalization which works for me.Ā  I can also reproduce in our SandBox environment and three different shortcuts.Ā  I feel like it is something associated to her user account, but can still reproduce it even if I give her Sys Admin access.
      Lori
      Lori Holmes
      Bridgewater, NJ
    • Mark Zerr
      December 21, 2018 at 2:21 PM
      What about a temp profile possibly.Ā  Not sure if she’s logging into through a terminal server or local client but maybe she’s not really under her own profile but a temp profile.Ā  Just a thought.
      Mark Zerr
      AX Technical Analyst
      New Sunshine LLC
      Indianapolis IN
    • Lori Holmes
      January 4, 2019 at 5:01 PM
      Hi Mark, thank you for the reply – we will check that too!
      Lori Holmes
      Bridgewater, NJ
    lholmes@hamamatsu.com replied 7 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Help Searching Customer Account Field 2012 RTM’ is closed to new replies.
