Global Personalization
  • Global Personalization
    Posted by Mark Yankovich on May 16, 2019 at 2:33 pm
    • Mark Yankovich
      May 16, 2019 at 2:33 PM
      Can global personalization’s be done?Ā  If so, how?
      #AX2012
      #Beginner
      #Admin
      Mark Yankovich
    • Katherine Linder
      May 17, 2019 at 3:08 PM
      Hello Mark,
      Refer to thisĀ document.Ā  Essentially, you will create the personalization, export and then import to users or role.
      Katherine Linder
      PowerObjects, an HCL Company
    • Zvika Rimalt
      May 20, 2019 at 2:08 AM
      Hi Katherine,
      Is that functionality also available in AX2012 (and not just 365?)
      I don’t have access to AX2012 but I don’t remember seeing that in AX2012
      Zvika Rimalt
      Functional Consultant
      Vancouver BC
    • Mark Yankovich
      May 21, 2019 at 7:37 AM
      Katherine,
      Thank you for your response.Ā  I read the ‘document’ link and noticed it was for D365, and did not find the same for AX2012.
      Mark Yankovich
    • Lynn Kinsman
      May 22, 2019 at 8:51 AM
      I also read the linked document for D365FO – Thanks Katherine!Ā  Sounds very similar to what AX 2012 has for sharing personalizations where one person can make it availableĀ  and then others can individually “retrieve from user” from that person.Ā  Ā The D365FO new ability for system administrators to manage that on behalf of many people wouldn’t be very useful to us since we only have a very few people allowed to have that level of access.
      Here is a blog post how to customize a button to share personalization across companies in AX, which might be what you meant by ‘global’ (our companies in AX are set up by country geographically.)Ā  But it is custom code.
      http://www.exploreax.com/blog/blog/2015/09/18/share-ax-user-form-customizations-between-companies/
      Lynn Kinsman
      Senior Systems Analyst, Pricing, Rebates, Projects
      Kodak Alaris Inc.
      Rochester NY
    • Chris South
      May 21, 2019 at 8:31 AM
      FYI, for d365FO there is a known defect that is targeted for PU28 to fix global personalization.Ā  If you create an advanced filter on a tile or list, it will probably fail to import the personalization.Ā  Its a real limitation if you want to create a custom workspace for a teamĀ  – ugggh.
      chris south
      SixAxis/ SafeRack
      Andrews SC
    Mark Yankovich replied 7 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Global Personalization’ is closed to new replies.
