Expense report error: “Dimension value XXX is not active.” (AX 2012)
  • Expense report error: “Dimension value XXX is not active.” (AX 2012)
    Posted by paul-ceely on February 2, 2021 at 5:31 pm
    • Paul Ceely
      February 2, 2021 at 5:31 PM
      Hi everyone!
      I have encountered a problem where, if a financial dimension value has an “Active from” date defined, users receive an error message that the value is “not active” when they try to enter/select the value on an expense report line (details below).Ā  Has anyone else experienced this? And is there a solution?
      Thanks in advance!
      When entering an expense report line, users receive an error message that a financial dimension value is “not active”:
      However, the financial dimension value is active:What I discovered from testing is that removing the Active from date allows the value to be used on the expense report line.
      #AX2012?? #Finance?
      Paul Ceely
      Group ERP Functional Support Specialist
      Britax
      SC, United States
    paul-ceely replied 5 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Expense report error: “Dimension value XXX is not active.” (AX 2012)’ is closed to new replies.
