Error Message
  • Error Message
    Posted by DSC Communities on January 16, 2017 at 4:41 pm
    • Blaine McGillivray
      January 16, 2017 at 4:41 PM
      Good day – has anyone else got this error message? Earlier today with this message our DAX 2012 R1 locked out all users to printing order reports and processing orders ie: Shipping.
      Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics
      Blaine McGillivray
      Food Services of America
      Scottsdale, AZ 85254 AZ
    • Zaheer Pottayil
      January 17, 2017 at 10:14 AM
      Blaine,
             Are you using terminal services? I have seen a similar message when the terminal server is out of disk space. Can you verify if all your servers have ample disk space?
      Zaheer Pottayil
      Waukegan IL
    • Scott Morley
      January 16, 2017 at 5:49 PM
      Blaine,
      In System admin, in Online Users, check the online users count. I have seen this issue when the number of connections exceeds the allowed connections on an AOS (default is 2000). If there is a custom or 3rd party app using the business connector or AIF and the sessions aren’t closing correctly, the AOS can still consider them connected even through they are not. Restarting the AOS clears it up as it forces all the connections closed.
      Scott Morley
      OneNeck IT Solutions
      Bend OR
      January 23, 2017 at 10:19 AM
      Scott – a Windows upgrade on our AOS servers caused the users to loos connection to the DAX DB. Funny the uses could use DAX but not update anything. Restarting the AOS services and SSRS got everything back aligned.  Thanks for your comments. Blaine
      Blaine McGillivray
    • Sebastien Ferland
      January 24, 2017 at 9:26 AM
      Not sure if this was you case specifically, but on our side we had the database restart (failover) one day and AX “seemed” to be up until a specific action of the user.  It seems the AOS keeps reference to temp tables in the tempdb database.  The tempdb was flushed on the failover and thus gave big error message to the first user that logged in AX and used one of those temp table.
      Sebastien Ferland
      Medisys Corporate Health
      Montreal
The discussion ‘Error Message’ is closed to new replies.
