Docentric/Lasernet for Invoices
  • Docentric/Lasernet for Invoices
    Posted by Morgan Main on October 8, 2026 at 3:46 pm
    Does anyone use either Docentric or Lasernet for invoice template creation in D365FO? If so, how has it performed when generating and distributing a high volume of invoices on a daily basis? I’m particularly interested in reliability, performance, and any challenges you’ve encountered.
    Hardik Gupta replied 1 month ago 2 Members · 1 Reply
  • 1 Reply
  • Hardik Gupta
    October 9, 2026 at 10:49 am
    Hi @morgan-mainjasperengines-com
    We’ve worked with both across multiple F&O implementations. Here’s what we’ve seen:
    Lasernet: Performs very well for high-volume batch runs. Designed specifically for this use case. Fast, reliable, and handles thousands of invoices without hiccups. Configuration is straightforward for standard invoice flows.
    Docentric: More flexible on template design and customization. Also handles high volume well, but requires more fine-tuning if you have complex invoice requirements (project invoices with variable layouts, multi-language, etc.).
    Key challenges we’ve encountered with both:
    – Batch job timing – you’ll want to schedule runs during off-peak hours to avoid performance impacts
    – Distribution logic – emailing thousands of invoices needs proper queuing or you’ll hit throttling
    – Archive storage – high-volume runs generate large PDF archives; plan for storage scaling
    Our recommendation: If your invoices are mostly standard layouts, Lasernet is your faster path. If you need flexibility on design, Docentric gives you more control.
    Happy to chat more if you want specific configuration insights.
