Delete a production order – AX 2012 R2 CU8
Posted by Unknown Member on January 30, 2017 at 1:04 pm-
Hello All,
I’m trying to delete a production order because the user posted in the wrong unit of measure. Anyway, several journals had already been posted for the order and I need to reverse it. I set the status back to create but then I get a message that I can’t delete it because I need to release items first. See attached.
Ideas on how I can delete the order?
Let me know.
Sam
Sam Clark
Business Systems Analyst
Team Technologies
Morristown TN
And you’ve already created a new pick list journal for a full reversal of all material and posted it?
Sean Blais
Operations Support
Sutphen Corporation
Dublin OH
Emily Tsang
MemberFebruary 1, 2017 at 2:08 PM
I have the same problem, after reset to create, this infolog popped up., i try the full reversal, still not working.,
Emily Tsang
production control manager/master scheduler
Teledyne Technologies Inc
san diego CA
Hi Sean,
Strangely we have never done this step when setting orders back to created. I did however, see this on a blog this morning and I tried it. The journal came back with a message that said ‘no lines were created’.
Thoughts?
Sam
Sam Clark
Team Technologies
Morristown TN
Try remaining qty, zero out the consumption and check “End” on each line. This should release the BOM.
Richard Wehmeyer
PlayCore
Chattanooga TN
Morning,
The pick lists have already been posted so I can’t zero out the consumption and ‘End’ it.
Usually once I change the order to ‘create’ it reverses everything, but this time it’s hung up.
Thoughts?
Sam
Sam Clark
Team Technologies
Morristown TN
The Consumption=Proposal box was checked when you performed the full reversal?
Sean Blais
Operations Support
Sutphen Corporation
Dublin OH
Hi Sean,
It doesn’t let me do a ‘full reversal’ at all. Says ‘no journal lines created’.
Sam
Sam Clark
Team Technologies
Morristown TN
Elliot Finn
MemberJanuary 31, 2017 at 12:57 PM
HI
Have you tried doing a Production order consistency Check. Should be found in Production control > Periodic > Production order consistency check. That should bring up the following box, just click select, enter the Production order as criteria, then click OK.
That often works for me when a work order is hung up.Cheers
Elliot Finn
Assistant Systems Administrator
Dairy Goat Co-operative (NZ) Ltd
Hamilton New Zealand
Try this link
Dynamics AX: Deleting a Production Order After Posting a Picking JournalTridea Partners Blog remove preview
Dynamics AX: Deleting a Production Order After Posting a Picking Journal This post outlines the steps required in Microsoft Dynamics AX to reset the status of a production order in order to delete the order. Once a production order has been picked you will need to reverse the picking list before resetting the status and deleting the order. View this on Tridea Partners Blog > ——————————
Paul Martin
Expert ERP Analyst
TempurSealy Inc.
Trinity NC
Thanks everyone for all the great input!
Sam
Sam Clark
Team Technologies
Morristown TN
Unknown Member replied 9 years, 9 months ago 1 Member · 0 Replies -
The discussion ‘Delete a production order – AX 2012 R2 CU8’ is closed to new replies.
