I could not find a report that shows customer pools and their criteria in Dynamics AX 2012 R3.Ā I went to first create a sQL query before creating my own report but it would seem as though the field that creates the criteria lives inĀ CustCollectionsPool.QueryPacked.
How do you extract that data in a SQL query so you can display the actual criteria used to query the customers in each pool?
The only workaround I found was to click on each pool in each company, Ctrl+T to Excel, and then copy and paste.Ā This represented 53 different pools across 13 companies, and 128 total criteria across those pools.Ā Not desirable.
Thank you.
—————————— Mark Jones Lead IT Business Analyst Unigroup Fenton MO ——————————
Robert Shannon
May 31, 2018 at 6:29 PM
You could use the functions found in the second part of this article:
Sometimes it might be useful to display a query you have created in the AOT to the user. After this the user makes changes to the query (adds ranges and sort fields) and you would like to save the query (as changed by the user) to a table in the database, therefore saving the state of the query as modified by the user.
