Check set up in AX
  • Check set up in AX
    Posted by nazimlalji@hotmail.com on December 10, 2018 at 5:47 pm
    • Najeem JanatAli
      December 10, 2018 at 5:47 PM
      HiĀ
      Any one have any documentation of “check set up” in AX under check layout. I am trying to understand these tabs : Gemeral, Setup, Codes how they impact and play role in check set up
      I have to set up Wells Fargo bank check set up
      thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • Mark Schurmann
      December 11, 2018 at 9:06 AM
      Question 1 is are you printing to pre-printed check stock or blank stock.Ā  We are printing to pre-printed and really didn’t have to mess with much on the layout screen:Ā  Check form and the Layout fields, signatures.Ā  We need to have a developer tweak the position of fields on the related SSRS report and there was a lot of back and forth to get it right. Ā
      I’m afraid I can’t comment on the blank stock scenario.
      Mark Schurmann
      Accounting Systems Manager
      Automobile Protection Corp
      Norcross GA
    • MARY LYNN KINCHEN
      December 11, 2018 at 9:21 AM
      Nazim,
      This is a very basic check layout structure depending on what you are trying to do.Ā  If you want AX to generate a continuous check number the check number method has to be fixed.Ā  If you can provide more information on what you are trying to do(paper check, upload file)?Ā  and what kind of printing device, we use Planet Press to generate our printed checks, I may can guide you more.
      MARY LYNN KINCHEN
      Sr Systems Analyst
      SNF HOLDING COMPANY
    • Bradley Bertchie, PMP
      December 11, 2018 at 10:28 AM
      This is for 2012 but will be the same for D3
      https://docs.microsoft.com/en-us/dynamicsax-2012//check-layout-form
      D3FO Project Manager / Financial Functional Consultant
      Fullscope an Alithya Company
      Denver CO
    nazimlalji@hotmail.com replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Check set up in AX’ is closed to new replies.
