Bulk User import
  • Bulk User import
    Posted by Amber Aaron on December 5, 2021 at 4:00 pm
    • Amber Aaron
      December 5, 2021 at 4:00 PM
      Hello is there a way to import many user accounts into D365 F&O at one time? I attempted to use excel add-on and update the design table but I get the error that the workbook could not update
      Amber Aaron
      Summit Racing Equipment
      Tallmadge
    • Kamar Wilks
      December 6, 2021 at 7:09 AM
      Hi Amber
      Excel Add-In
      I have not used Excel Addin for this before but my suggestion is to check that all fields available for the add-in are in your file and are accounted for. I have seen before where the add-in does not work unless all fields are showing in the selected fields area. You may do so by
      1. Click on design
      2. Click on the edit icon for the data entity
      3. In the Available Fields section do CTRL+A then click on add under Selected Fields. All Fields will now be displayed in the Selected Field section.
      4. Click on Update
      5. Fill in the necessary fields and try to publish again
      Data Management
      You could manually fully set up one user. Then use data management to export the user information. Amend the file exported by adding all the other users and modeling them after the one you had manually created. Import the amended file back into D365 and see if that works.
      If you have users in different countries please pay attention to language, country, and timezone in your file.
      Kamar Wilks
      BlueCrest Inc
      Danbury
    • Amber Aaron
      December 9, 2021 at 4:46 PM
      Thank you so much I went with DMF
      Amber Aaron
      Tallmadge
    • Kerstin Newman
      December 6, 2021 at 9:03 AM
      Are you importing them from AD? If so, you go to the users screen and click “Import Users” and can select as many as you want to all import at once:
      Kerstin Newman
      Business Analyst
      StarTech.com
      London ON
    • Amber Aaron
      December 9, 2021 at 4:47 PM
      Thank you Kerstin! We are on-prem so syncing our AD doesn’t work properly for some reason.
      Amber Aaron
      Tallmadge
    Amber Aaron replied 4 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Bulk User import’ is closed to new replies.
