Budget column not showing numbers in Management Reporter, AX 2012 R3
  • Budget column not showing numbers in Management Reporter, AX 2012 R3
    Posted by nazimlalji@hotmail.com on May 1, 2019 at 2:28 pm
    • Najeem JanatAli
      May 1, 2019 at 2:28 PM
      Hi All
      In 2019, uploadedĀ  2 budgets one in Jan and another in Apr. While running the comparative report (actual vs budget), MR pulls data for actual as well as Jan budget.Ā  However when changed to Apr budget it appears blank. Any suggestion to trouble shoot this issue
      Thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • Mark Bailey
      May 2, 2019 at 6:12 AM
      Hi Nazim,
      Have you run the “Refresh cached financial data” routine under the tools menu in MR??Ā
      After that the first thing I would check is the source data. Are there any entries for April?? If not MR has no data to present.
      Next look at the column definition set up and check what is populated under:
      • Book code/ attribute category
      • Period
      • Period covered
      • Attribute filters.
      Make sure these settings relate to the budgets you have in the system.
      If all else fails as your technical team to reset the data mart in MR.
      Kind Regards
      Mark
      Mark Bailey
      Application Consultant
      Annata
      Portsmouth
    • Najeem JanatAli
      May 2, 2019 at 7:34 PM
      Mark
      refreshed cached financial data.Ā
      Checked column definition,Ā  Book code/ attribute category, Period, Period covered, Attribute filters.
      Please can you advise steps to reset Data mart or any other suggestion
      Nazim Lalji
      Dynamics AX Analyst
    • Mark Bailey
      May 7, 2019 at 4:58 AM
      Hi Nazim,
      In AX2012 R3 the refresh of the data mart is done from the SQL server DB.Ā
      Kind Regards
      Mark
      Mark Bailey
      Annata
      Portsmouth
    • Katrina Breedlove
      May 2, 2019 at 9:04 AM
      ?I think the budget has to be in completed status (not draft) before Management Reporter will show the numbers.
      Katrina Breedlove
      Systems Analyst
      Seminole Electric Cooperative
      FL
    • Steve Latta
      May 2, 2019 at 9:33 AM
      ?Look on your column definition and verify that the book code/attribute category is set to pull the budget model name you uploaded for April.
      I personally prefer to set up a top level budget model that I reference in Management Reporter and then add any additional budget models as submodels underneath that one. That ensures I don’t have to update MR column definitions when loading the budget for a new year, for example.
      Steve Latta
      Accountant
      Ortec, Inc.
      Easley SC
    • Najeem JanatAli
      May 2, 2019 at 7:31 PM
      Hi Steve
      Column definition is good. When column definition checked and comparedĀ  with Budget V1 and Budget V2, its same. Budget V1 numbers areĀ  showing in MR and Budget V2 not.
      budget V1 was uploaded in Feb 2019, where as Budget V2 uploaded in AX in April, not showing in MR
      Any thoughts to trouble shoot, please advise
      Nazim Lalji
      Dynamics AX Analyst
    • miguel Devezas
      April 25, 2022 at 3:21 AM
      Hello!
      Did you manage to get the data? I am struggling with the same problem at the moment
      miguel Devezas
      KKCCTT
    nazimlalji@hotmail.com replied 7 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Budget column not showing numbers in Management Reporter, AX 2012 R3’ is closed to new replies.
