AX 2012 crashes
  • AX 2012 crashes
    Posted by nazimlalji@hotmail.com on August 17, 2017 at 8:07 pm
    • Najeem JanatAli
      August 17, 2017 at 8:07 PM
      HI All
      After personalizing Purchase Order bar, now when ever I click PO under all PO whether from PS or AP, it crashes AX 2012,
      please advise how can I Ā resolve this issue
      thanks
    • Sherry Moran
      August 18, 2017 at 10:24 AM
      ?As others have said clear your usage data.Ā  You can clear all your usage data
      1. File
      2. Tools
      3. OptionsĀ
      4. Usage DataĀ
      5. ResetĀ
      Or you can selecting clear usage data which is what we start with first
      1. File
      2. ToolsĀ
      3. OptionsĀ
      4. Usage DataĀ
      5. All Usage TabĀ
      6. Filter for Element Name *PurchTable*Ā (or the area you personalized)
      7. Select the Usersetup records by checking box on Left side
      8. File –> Delete Record
      As a cautionary I always have the user close AX and re-open before doing anything again to make sure it all clears.Ā  The second one usually helps our users and we only go to the first option if we can’t figure out where the personalization is.
      Sherry
      Sherry Moran
      SR Business Systems Analyst
      Key Technology, Inc
      Walla Walla WA
    • Avtar Dhillon
      August 18, 2017 at 7:17 AM
      try resetting your usage data.Ā
      Avtar Dhillon
      RSM US LLP
      New York NY
    • Paul Martin
      August 18, 2017 at 8:25 AM
      ?Although personalization is availableĀ  I have found that it should only be in grids, we have users that personalize heavily and when they get it to the point it crashes, the only resolution is clearing their usage data. also personalizing the action panes is not a terrific idea.
      Paul Martin
      Expert ERP Analyst
      TempurSealy Inc.
      Trinity NC
    • Allen Rupp
      August 18, 2017 at 2:27 PM
      This is not the first time I have heard that personalizations should be limited.
      What is the cost effective alternative?
      Allen Rupp
      Purchasing Manager
      Woodland Foods
      Waukegan IL
    • Soren Rasmussen
      August 18, 2017 at 2:57 AM
      1. Try and delete the AUC files from your machine.
      2. Try and delete the usage data for the form you created.
      Soren Rasmussen
      SSS Australia
      Murarrie
    nazimlalji@hotmail.com replied 9 years, 2 months ago 1 Member · 0 Replies
The discussion ‘AX 2012 crashes’ is closed to new replies.
