Active document tables in AX 2012, whats the purpose
  • Active document tables in AX 2012, whats the purpose
    Posted by nazimlalji@hotmail.com on March 11, 2020 at 3:20 pm
    • Najeem JanatAli
      March 11, 2020 at 3:20 PM
      Under Org Admin -> set up -> Document management -> Active document tables
      Whats the purpose of setting up, please advise
      Thanks and kind regards
    • Shirley Adams
      March 12, 2020 at 9:11 AM
      I have used this to force document handling to work differently than out of the box defaults for two primary areas:
      1) Force document handling to only be available for certain tables (requires ‘use active document tables’ to be set to yes in parameters)
      2) Allow attachment editing/adding to posted documents (for example, GL entries)
      Note that for #2, you don’t need to mark to use active document tables for it to work – you just mark the ‘enable always’ checkbox next to the table you are applying that setting to.?
      Shirley Adams
      Solution Architect
      AKA Enterprise Solutions
      New York NY
    nazimlalji@hotmail.com replied 6 years ago 1 Member · 0 Replies
The discussion ‘Active document tables in AX 2012, whats the purpose’ is closed to new replies.
