A property for a journal batch number has more than one value. Data management GL template import issue
  • A property for a journal batch number has more than one value. Data management GL template import issue
    Posted by nazimlalji@hotmail.com on August 26, 2021 at 2:14 pm
    • Najeem JanatAli
      August 26, 2021 at 2:14 PM
      Hi All
      Trying to import General Journal template through data management, keep receiving below error, any suggestion
      A property for a journal batch number has more than one value. Update the journal batch number properties to be the same for all lines assigned to the same journal batch number.
      Thanks and kind regards
    • Ian Gorman
      September 1, 2021 at 9:53 AM
      Najeem,
      Perhaps you can provide a few screenshots of the data you’re attempting to import back into D365 so we could review it. Sounds to me like your initial column, dictating the JGN, is not the same value and is most likely changing values per line.
      Ian Gorman, PMP, MCSE
      MCA Connect
      Solution Architect
    nazimlalji@hotmail.com replied 4 years, 7 months ago 1 Member · 0 Replies
The discussion ‘A property for a journal batch number has more than one value. Data management GL template import issue’ is closed to new replies.
