Hi, non-WMS warehouses still use locations. However, the form to set up the locations is in a different menu path. They are not configured/created in the Warehouse management module. You set up aisles and locations for nonWMS warehouse in the Inventory management module > Setup > Inventory Breakdown > Inventory aisles and Inventory Locations.
If you configure an aisle against your nonWMS warehouse, you should then be able to go into Inventory locations and create a location for it as well. After that, it can be assigned as a Default receipt and/or issue location on the Warehouse form.
