Hi Rod, yes the workflow parameters setting under system admin will disallow submitters to approve journals across all modules. If you are using a User Group or other options not user specific in your workflows it should still allow a user to approve other users journals just not there own. I would make sure you are using User Groups at least in your workflow setups and not just selecting users.
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
