Sending to Excel take the system down?
  • Sending to Excel take the system down?
    Posted by Jason Wilder on May 25, 2017 at 9:09 am
    • Jason Wilder
      May 25, 2017 at 9:09 AM
      Since we have gone Live with NAV 2016 in Jan 2017 about twice a month our Service Tier crashes.Ā  Most of the reasons have an explanation that we have gotten to the bottom to but there are two times that we are trying to figure out what happened.Ā  I have a sneaking suspicion (based on user feedback) that it is a user hitting the send to excel button on a list screen with millions of records.
      The most recent example is someone removed their filter on the Item Ledger Page and hit the Excel button which would try to send over 17 million ILE records to Excel.Ā  NAV slowed to a crawl and then kicked everyone out.Ā  Simply restarting the service tier solved the problem.Ā
      Can anyone else confirm this has happened to them?
      If yes I know the fix is to set the following property in the service tier to a more reasonable number:
      Jason Wilder
      Senior Application Developer
      Stonewall Kitchen
      York ME
    • Mike Louis
      May 26, 2017 at 5:10 PM
      Hi Jason,
      I haven’t had that experience, but if you have established that the user’s actions of exporting to Excel are the root cause, then one thing that you could try is this, but please research further before doing:
      Source of information: https://msdn.microsoft.com/en-us/library/dd301077(v=nav.90).aspx
      Have the user close out of NAV.
      ThereĀ is a config file at:
      File name: ClientUserSettings.config
      C:Users<username>AppDataRoamingMicrosoftMicrosoft Dynamics NAV90
      Open the ClientUserSettings.config in Notepad.
      Save a copy of the fileĀ in another folderĀ in case you need to revert back.
      Look for the row below, or if it doesn’t exist, please add in:
      <add key=”MaxNoOfXMLRecordsToSend” value=”10000″/>
      Save file (don’t overwrite the copy).
      Start up NAV.
      They should get an error message if they try to export more than the stated number of records (10,000).Ā
      Best Regards,
      Mike
      *provided “AS IS”, no warranty expressed or implied, and confers no rights.
      Mike Louis
      Business Systems Analyst
      Cogentix Medical
      Minnetonka MN
    • Geovanny Fuentes
      May 29, 2017 at 2:39 AM
      Please review the event viewer, it will tell you a lot. User causing issue, things leading up to it.
      Could be a service pack update on the server.
      Look at the server resources in task manager, user count, etc.
      Find the routine then ask users who was doing what.Ā
      Good luck.
      Geovanny Fuentes
    Jason Wilder replied 9 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Sending to Excel take the system down?’ is closed to new replies.
