Saved filters with different column layouts
  • Saved filters with different column layouts
    Posted by Becky Kaiser on February 15, 2024 at 9:52 am
    In BC14 you were able to setup saved filters where you could have different column headers within those filters. In BC23 you can still setup saved filters, but I am not seeing where each filtered list can have different column headers. Any advice on how to have different columns within those lists.
    Example: I have 4 saved filters in screenshots attached – Quick Editing, Quick Edit, Items UoM-lbs per pallet=0, and Inventory List UoMs. Within each of those I would like different column headers such as in Quick Editing I want the first column to be No. but in the Inventory List UoM-lbs I want the first column to be the Description etc.
    Lewis Rosenberg replied 1 year, 7 months ago 2 Members · 1 Reply
  • 1 Reply
    February 15, 2024 at 3:02 pm
    Hello @becky-kaiserselect-cs-com ,
    I just tested this in BC14 and BC22 and confirm that they behave differently. BC22 does not allow different column layouts as far as I can tell for different saved filtered lists.
    In BC14 (using the RTC), I was able to have a different column layout for different saved filtered views. After creating the views I logged into the BC14 Modern (web) client and the column layouts were still different for my two different saved views from the same page. I did not try creating the saved filtered views in the modern client.
The discussion ‘Saved filters with different column layouts’ is closed to new replies.
