REPORT.SAVEASPDF hanging in NAV 2013 R2
  • REPORT.SAVEASPDF hanging in NAV 2013 R2
    Posted by oliver-leslie on July 17, 2018 at 10:22 am
    • Oliver Leslie
      July 17, 2018 at 10:22 AM
      Good morning!
      We have a Report in NAV 2013 R2 which calls the Inventory to G/L Reconcile report (10138) to run in the background, then email the results to user as a PDF sent by SMTP in NAV:
      We are having an issue where – depending on the date range provided to the report – the report does not complete. In turn, this leaves a hanging NAV user session which can only be killed by deleting from the Active Session table, and leaves a file handle open to the PDF it attempted to create on the service tier machine. The only way to release the open file and try the report again, is to restart the NAV service.
      Is there a limit to how much data the REPORT.SAVEASPDF command can handle? The other possibility I am considering is a piece of bad data somewhere in the result set.
      The steps the report goes through every time seem reliable to measure:
      > NAV begins running the report and processes for around 8 minutes (Screenshot 1, attached)
      > After 8 minutes, a PDF file is created in the specified folder on the service tier (Screenshot 2, attached) and begins writing (Screenshot 3, attached)
      > After a further 4 minutes from the date/timestamp of the file on the server, the process will either complete or fail
      > If completes successfully, CPU activity drops off, the PDF file is closed, and the size updates from 0 KB to, say, 900 KB (Screenshot 4, attached)
      > If it fails, the file remains open, file size 0 KB, and the CPU and memory beginning ‘bobbing’ up and down – this will continue until the server is restarted (Screenshots 4 & 5, attached)
      Any advice would be greatly appreciated – thank you!
      Olly
      Oliver Leslie
      HOLLY HUNT Enterprises
      Chicago IL
    • Jon Long
      July 17, 2018 at 1:23 PM
      I would try eliminating all fields from the report except one. Then keep running it and adding fields back until it crashes. Quite often, when a report hangs, to PDF, or otherwise, there are RAM ramifications (no pun intended) where several hundred Calcfields chew up resources to the point it freezes.Ā
      If it is a flowfield, you can remove it if you don’t need it in the output, or, create a better key in the dependent table.
      Jon Long
      Director of ArcherPoint-Upgrades
      ArcherPoint Inc.
      GA
    • Jeroen Bennink
      July 18, 2018 at 3:24 AM
      I suggest to look at the Service config-file the paramater “NetFx40_LegacySecurityPolicy enabled”.
      We experienced bad perfomance with this paramater set to “false”. The performance increases when updating it to “true”.
      Jeroen Bennink
      Nedap N.V.
      Groenlo
    • Ron Ketterling
      July 18, 2018 at 7:07 AM
      I have seen this report fail because of the old 2GB temporary file limit in Windows. Or, you may be filling your OS drive. This report can create huge files.
      Ron Ketterling
      President
      Minneapolis MN
    • Ron Ketterling
      July 18, 2018 at 7:09 AM
      A further thought. There may be a fix for this report for 2013 R2, if I recall correctly.
      Ron Ketterling
      President
      Minneapolis MN
    • Geovanny Fuentes
      July 19, 2018 at 1:03 PM
      Try a few steps to narrow the run time,
      One is limit the options selected.
      Avoid popup displays on the report.
      Run it manually and see how long it takes, then run it without sending the email, time it and see why the server is longer.
      Try next a SLEEP(6000) or what ever seconds before sending the email and see if it gives it enough time.
      Try saving it in a different server/folder (Where the service tier is running).
      Good luck.
      Geovanny Fuentes
      San Diego CA
    oliver-leslie replied 8 years, 3 months ago 1 Member · 0 Replies
The discussion ‘REPORT.SAVEASPDF hanging in NAV 2013 R2’ is closed to new replies.
