Report for item consumption?
  • Report for item consumption?
    Posted by Devora on December 5, 2018 at 11:29 am
    • Devora Locke
      December 5, 2018 at 11:29 AM
      ?Cannot find it now, but thought there was aĀ report within NAVĀ 2016 that shows quantity of items in an Assembly consumed, as well as remaining quantity on hand.Ā  We’re tried to create such a thing with a NAV view as well as with Jet, but can’t seem to get the numbers to reconcile. A little tricky using Item Ledger Entry as it requires an accurate set of specific filters.Ā
      Ideally I am looking for items used for Assembly ordersĀ only,Ā  plus quantity remaining (in stock)Ā so that purchasing can run a little leaner when it comes to ordering.Ā  Anyone?
      Thanks and Regards,
      -Devora
      Devora Locke
      Shin-Etsu MicroSi, Inc
      Phoenix AZ
    • Jeane Meade
      December 6, 2018 at 9:11 AM
      NAV 2015 here.
      We created a report in Excel using PowerPivot that uses the Item Ledger Entry table from SQL and a NAV Query.Ā  The NAV query shows the QOH and the ILE table shows Items consumed for raw materials and subassemblies.Ā  Two NAV Query filters – inventory posting group and item type (we exclude discontinued items) – QOH always matches item card as QOH flow field is used. Ā  SQL – three filters – inventory posting group, entry type – assembly consumption, and item type.Ā  The SQL query is written right in PowerPivot (it’s pretty simple, uses table view), the NAV query is pulled into Excel and then “added to the data model”.Ā  Relationship set on Item no.Ā  Add the required measures…
      That is the simple overview, there are some exceptions, but we are able to address them either in the query or sql code.
      Jeane Meade
      IT/DBM
      Sheldons’, Inc.
      Antigo WI
    • Mark Williams
      December 6, 2018 at 9:16 AM
      You may want to try the Item Transaction Detail Report.Ā  There are a TON of options available to run the report so start small with a single item #Ā you know you’ve used in an assembly an a narrow date range.Ā  The bottom filter section is the magic, it has a selection for Transaction Type, use ‘Assembly Consumption’.Ā  I use this field to develop SQL queries.Ā  There’s also a section for Production Consumption that is just called ‘Consumption’.
      I think the out of the box version of the Item Transaction Detail report will show you quantity on hand as well.
      Hope this helps.
      Mark Williams
      MED-EL Corporation
      Durham
    Devora replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Report for item consumption?’ is closed to new replies.
