Record Templates
  • Posted by Noreen Fujita-Sacco on November 3, 2022 at 7:43 pm
    • Noreen Fujita-Sacco
      November 3, 2022 at 7:43 PM
      Hello,Ā
      For NAV 2018, are the record Master Templates limited to Customer, Vendor, and Item cards? I’m particularly interested in setting up the Ship-to Address Cards with default field values.
      If this is a NAV 2018 limitation, are additional records available to set templates in BC?Ā
      Thank you!
      #NAV 2018
      Noreen Fujita-Sacco
      Applications Coordinator
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
      noreen.fujitasacco@gearaid.com
    • Brad Prendergast
      November 4, 2022 at 9:18 AM
      Templates are available for Customers, Vendors, Employees and Items. You could use configuration templates, but it would require a modification.
      Thanks, and Best Regards,
      Brad Prendergast
      November 4, 2022 at 9:56 AM
      I’ve used templates for some other tables using the CREATE INSTANCE action in the ribbon on the template card.
      This would be tricky and would probably require a modification for customer ship-to’s because the table has a multiple-field key (Customer Code + Ship-to Code).
      Mars Fishcare/Mars Horsecare
      http://www.apifishcare.com
      D365UG-BC/NAVUG All-Star
      Twitter: @RosenbergL
      November 4, 2022 at 12:06 PM
      Thank you, all. It sounds unanimous that a customization is required even in BC. I appreciate your responses!
      Noreen Fujita-Sacco
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
    Noreen Fujita-Sacco replied 3 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Record Templates’ is closed to new replies.
