There is a system table called 2000000068 Record Links that store Notes and Record Links.Ā In NAV you would use the Record ID of your Customer and filter on this table something likeĀ Customer.Record ID = Record Link.Record ID and Record Links.Type = Note.Ā Then you would need to stream the blob field called “Note” that holds the text of the note.Ā This is pretty easy to do from the NAV development environment.
Can’t imagine anything else that can do this including Jet reports since these fields are stored in a different format in SQL.Ā If you look at the Record Link table in SQL you will see both the Record ID and Note fields look like gibberish.
—————————— Jason Wilder Senior Application Developer Stonewall Kitchen York ME —————————— ——————————————-
