Purchasing Error Message…
  • Purchasing Error Message…
    Posted by Kim Haw on August 17, 2022 at 4:09 pm
    • Kim Haw
      August 17, 2022 at 4:09 PM
      Good afternoon,
      I set up a new vendor in the Purchasing Section of Business Central.Ā  After set up, when I tried to add a new purchase invoice, I am receiving the following error message:
      • You have modified Tax Area Code.Ā  Do you want to update the lines?Ā
      I cannot seem to add any new invoices for this particular vendor.Ā  Any suggestions?Ā Ā
      Any help is appreciated.Ā  Thanks!
      Kim Haw
      Mathematical Research Inc., dba MRI Technologies
      Houston
    • Lindsay Riggs
      August 18, 2022 at 2:39 PM
      Hi Kim,Ā
      Check that your new vendor has the correct Tax Area Code as a default on their card.Ā
      Then when you do a Purchase Invoice, you will want to ensure the Tax Area Code is on the header and all the lines on the purchase invoice so this warning doesn’t persist.Ā
      Thank you,
      Lindsay Riggs
      Senior Manager, Microsoft Dynamics
      MorganFranklin Consulting LLC
      lindsay.riggs@morganfranklin.com
      _______________________________________________
      LinkedIn: http://www.linkedin.com/in/lindsaylriggs
    Kim Haw replied 3 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Purchasing Error Message…’ is closed to new replies.
