Prod. Order with Capacity Ledger Entry but no Output
  • Prod. Order with Capacity Ledger Entry but no Output
    Posted by oliver-leslie on November 17, 2020 at 11:13 am
    • Oliver Leslie
      November 17, 2020 at 11:13 AM
      #NAV2013R2 #Manufacturing??
      Good morning –
      I wonder if you could help me with a process question – we have a Production Order which was ultimately requested to be cancelled, so we need to either delete it or change its status to Finished.
      The issue is, one of the subcontract purchase orders was received, so it created a Capacity Ledger Entry, but no inventory output.
      I have read a few articles online suggesting using the Production Journal to reverse the capacity entry, then output the inventory, then negatively adjust it back out of inventory in the item journal – however, I am running into a few errors.
      Can you please look at the screenshots attached and let me know if I am on the right track?
      (1) Attempt to delete Prod. Order:
      (2) Attempt to change Prod. Order status to Finished:
      (3) Attempt to post negative capacity journal line – I don’t see any field to allow me to add Location Code to the journal line – I’m also unable to associate it with any routing operation no.
      Thank you!Ā
      Oliver Leslie
      HOLLY HUNT Enterprises
      Chicago IL
    • Ben Baxter
      November 18, 2020 at 8:22 AM
      Oliver,
      The journal pulls the Location Code from the Production Order itself.Ā  You may need to make this field visible in the Journal, or update the Production Order with a Location.Ā  You may have to update this on the Routing since you are posting a Capacity cost.
      Once you are able to post your reversing entry and Output a single unit, you should be able to change the Status of the Production Journal to Finished.Ā  Don’t forget to Item Journal the unit produced back out of inventory.
      You are on the right path, just missing some data in the Location field.
      Ben Baxter
      Consultant
      Accent Software, Inc.
      Carmel, IN
    • Oliver Leslie
      November 18, 2020 at 3:42 PM
      I took a look at this again today in our test environment and was able to reverse the capacity, post the output, and adjust it out, all as expected – not sure what I was doing wrong before – but adding the Prod. Order No. and the Item No. to the Capacity Journal line allowed me to drill-down to the Routing lines for the Operation No. which was not happening before – from there all other info populated correctly.Ā
      Thanks for your advice!Ā
      Oliver Leslie
      Chicago IL
    oliver-leslie replied 5 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Prod. Order with Capacity Ledger Entry but no Output’ is closed to new replies.
