Pop Up Notes
  • Posted by Chris-Soraparu on February 8, 2018 at 2:43 pm
    • Chris Soraparu
      February 8, 2018 at 2:43 PM
      How many characters can be used in the Pop-Up notes sections?
      Chris Soraparu
      Tri Star Metals LLC
      Carol Stream IL
    • Greg Enns
      February 8, 2018 at 5:48 PM
      I don’t recognize that page, but if you look at the table definition in the dev environment, it should tell you if the field is BLOB or text. If it’s text, then the limit is defined there in the table definition. If it’s BLOB then I think it’s practically unlimited (up to 2 GB).
      Greg Enns
      ERP Coordinator
      Technical Prospects
      Kaukauna WI
    • Naveen Jain
      February 9, 2018 at 12:33 AM
      It seems it is a customization to your database. As Greg said design the table tide to this page and you will find the limit for this field
      Naveen Jain
      Director of IT
      Symbex Companies
      Santa Fe Springs CA
    • Jeffrey Mantz
      February 9, 2018 at 6:38 AM
      Pop-Up Notes is a 3rd party add on from Cost Control Software. The field you show is quite big but the actual notes are stored as a text field just like the comment sheets that NAV has built in as a standard function. If the text you put in that field is too big for the text field I believe it will automatically split it into multiple lines when saved.
      Jeffrey Mantz
      Zefon International
    • Maureen Youngblood
      February 9, 2018 at 11:17 AM
      As a former MAS200 user, I really miss pop-up notes.  It is a shame it not a standard feature in NAV.
      Maureen Youngblood
      U.S. Operations Manager
      Golden Omega USA
      Aliso Viejo CA
    • Naveen Jain
      February 9, 2018 at 12:19 PM
      Standard NAV has comments which can be used as notes and with small modification you can make them pop-up when you want them to show up. Also NOTES can be used to maintain running notes.
      Naveen Jain
      Director of IT
      Symbex Companies
      Santa Fe Springs CA
    • Rick Baxter
      February 9, 2018 at 9:28 AM
      Chris, Thanks for the question and thanks for using Pop-Up Notes by Cost Control Software. To be precise each note can have 250 Characters. And you can have unlimited notes per Vendor, Customer, Resource, or Item. Visit our Web Site for a Video showing how to use this awesome Add-n Granule.
      Rick Baxter
      Business Development
      Cost Control Software, Inc.
      Carmel IN
    Chris-Soraparu replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Pop Up Notes’ is closed to new replies.
