Payment not pulling through on Bank rec
Posted by DSC Communities on November 26, 2019 at 4:48 pm-
Jami Laddusaw
MemberNovember 26, 2019 at 4:48 PM
We’ve been having an issue with certain payments or invoices not pulling through to the bank recs but you can see them on the GL. The specific one I’m looking at has the “open” box checked under the Bank Account Ledger Entry section when I open the related entries where as the other payments from the similar vendor do not. I’m not sure if this is the issue or not, but what would cause a payment to not pull through on the bank rec but show up on the GL? How can you fix this?——————————
Jami Laddusaw
Mary T. Inc.
Jamie Longnecker
MemberNovember 27, 2019 at 8:53 AM
You have to make sure that the balancing account type in the payment journal is “bank account” not “G/L Account”.Ā You can also turn off direct posting for that specific account and it will not allow entries to be posted only to the general ledger for that specific account.——————————
Jamie Longnecker
GCSES
Gray
Jimmy Yu
MemberNovember 27, 2019 at 10:05 AM
Are you filtering your Suggest Lines option window?Ā Something as simple as this often gets over looked.——————————
Jimmy Yu
Step Energy Services Inc
AB
Jamie Constantine
MemberNovember 27, 2019 at 10:47 AM
Jamie Longnecker is correct.Ā Ā The Bank Rec relies on the Bank Ledger Entry and Check Ledger Entry tables.Ā If you do not post to a bank account, the entry will not commit a record to the Bank Account Ledger table and therefore will not show on the bank account rec process.Ā Ā
Cash General ledger accounts (along with AR and AP general ledger accounts) should be turned off for “Direct Posting”, as Jamie said above.Ā Ā Ā——————————
Jamie Constantine
Columbus Global
Alex Apodaca
MemberNovember 27, 2019 at 1:44 PM
?Hello Jami,
Every once in a while I see an issue like this caused by a payment that was added to a Bank Reconciliation statementĀ where the statement wasĀ deleted byĀ a user. Depending your NAV version, in this scenario NAV might not show it on a new bank rec because it thinks it’s already on one.
From the Bank Account Ledger Entries screen, select the line you are referring to, and go to Help => About This Page => and view the Table Fields for this line in the Bank Account Ledger Entries view. Check the following fields: Statement Line No, Statement No, and Statement Status to make sure this entry didn’t get put on a Bank Reconciliation statement that was deleted.
If my response has helped you please mark the answer.Best Regards,
Alex A
Sr. NAV Consultant
Los Angeles, CA, United States
Jami Laddusaw
MemberNovember 27, 2019 at 4:37 PM
Hi,When I’m in this field, the only things areĀ
Page:Ā Bank Account Ledger Entries (372)
Page Type: List
Page Mode: View
Source Table:Ā Bank Account Ledger Entry (271)
Rec: 96832The other things that were mentioned have all been checked and are ok. Again, the only thing I can tell different is the “Open” field in the Bank Account Ledger Entry field is checked and I’ve never seen that before and I don’t know what that does.Ā
Jami Laddusaw
Mary T. Inc.
Coon Rapids MN
Jamie Constantine
MemberNovember 28, 2019 at 12:30 AM
The open field is literally driven by the bank Rec process for bank ledger entries. So if something is open , it’s ready to be reconciled.Jamie Constantine570-878-1722——Original Message——
Page Type: List
Page Mode: View
Jami Laddusaw
Mary T. Inc.
Coon Rapids MN
Yusuf Newland
MemberNovember 28, 2019 at 7:12 AM
I have also experienced this when doing my Bank Rec.
if the open field is checked that means it should pull to the back rec1. Please check that the you can view the entry through the bank and not through the GL2. go to the bank card and select ledge entries and verify that you can see these entries3. If you cannot see them then it means that this was posted through the bank GL and not the bank account4. Verify that other entries from the same batch are pulling to the bank rec5. If you can see it in the bank but it is still not pulling to the bank rec I will suggest you do auto reverse and repost the entry againĀ
6. Always make sure the bank type is selected and not the GL type for payment
7. Please check your date filter on the Bank Rec——————————
Yusuf Newland
MGAC
Washintgon DC
Jami Laddusaw
MemberDecember 3, 2019 at 10:59 AM
Thanks, Yusuf. However, it did not help. I can see it on the bank card and I’m setting my date filter to let everything come through to October 31st. The items that are not pulling through are for August and one for October 4th. I thought I read somewhere that the result of this could be from a bank rec being deleted and the lines not being cleared before deleting. I have not deleted any bank recs, however, in trying to solve this, is there a way to search for deleted bank recs?——————————
Jami Laddusaw
Mary T. Inc.
Coon Rapids MN
Alex Apodaca
MemberDecember 3, 2019 at 2:52 PM
Hello Jami,
In response to your last message, please review my former response above. If this missing payment is tied to another bank rec (deleted or not) it will be discernible from the Statement No andĀ Statement Line No fields within that Bank Account Ledger payment record. I’ve excerpted the detail below for your convenience.
Note: Please be sure to click on the Table Fields fasttab to expand it so you can see all the fields related to this record. If you cannot see all the aforementioned fields from the view Table Fields page under Help => About This Page, then you may need to find a SUPER user to be able to see them.
Alex A
Sr. NAV Consultant
DSC Communities replied 6 years, 4 months ago 1 Member · 0 Replies -
The discussion ‘Payment not pulling through on Bank rec’ is closed to new replies.
