October”s Tips & Tricks!
Posted by Holly Kutil on October 2, 2017 at 2:30 pm-
Using My Customers, My Vendors, and My Items as filtersYou have likely come across the My Customers, My Vendors, or My Items lists on your Role Center page (your NAV home page). Depending on the Profile assigned to you, you may have one or all of these available to showĀ on your Role Center.
The functionality is pretty straightforward: If you frequently, or exclusively, workĀ with some customers (vendors, or items), you can click on Manage List in the My Customers page part to create a shortlist with just those records so you can quickly jump to one of them by double-clicking it right from the Role Center.
What most people don’t know is thatĀ you can use your “My” shortlists as filtersĀ all across NAV, on pagesĀ as well asĀ reports! It’s quite simple too. Just use these filter stringsā¦
- My Customers: %mycust
- My Vendors: %myvend
- My Items: %myitem
- Ā
We have found that %mycust worksĀ the same as %mycustomers, and similarly for the other two “My” lists.
More secret right-click optionsSecret right-click options revealed by the Shift key don’t end with file paths, though
The basic Send to tool that appears as an option when you right-click on a file or folder is handy enough indeed, allowing you to move the item quickly to a handful of locations on your PC, add it to a .zip archive, or send it off in an email or fax
But that’s just the tip of the iceberg! Holding down the Shift key as you right-click a file or folder will add an absolute ton of new folder locations to the basic Send to menu
Problem Steps Recorder
This little-known tool creates an HTML slideshow of your actions, recording your moves step-by-step so that you can show your IT admin or resident PC geek exactly what you’re doing when you run into a problem. It’s a huge boon during especially tricky troubleshooting situationsTo open the Problem Steps Recorder, simply search for psr in the Windows 7 Start menu or Windows 8’s Start screen. The tool should pop right up and is very straightforward to use
Holly Kutil
American Ring/NAV Admin
Solon, OH 44139
**Great Lakes Chapter**
?? Women In Dynamics ??
?I don’t think I ever saw that Problem Step Recorder before.Ā What a great tool that can be used if you are writing how-to instructions and want to include screen shots.
NAVUG Programming Committee
NAVUG Membership Committee
This is
neat.. Ā Didn’t know about the problem step recorder… Thanks for sharing, !?——————————
Meenakshi Singh
Home Market Foods, Inc.
Norwood MA
Oh that is nice. Thanks for showing us PSR, Holly.
Gregory Alford
ERP Manager
Tri Star Metals LLC
Carol Stream IL
Love the PSR, ! Thanks for sharing!
Greg Enns
ERP Coordinator
Technical Prospects
Kaukauna WI
Holly Kutil replied 9 years, 1 month ago 1 Member · 0 Replies -
The discussion ‘October”s Tips & Tricks!’ is closed to new replies.
