Notes on G/L Entry
  • Notes on G/L Entry
    Posted by Jason Wilder on October 10, 2018 at 9:14 am
    • Jason Wilder
      October 10, 2018 at 9:14 AM
      This is a must do mod for you accountants out there. Not joking, this is a super good add to NAV.
      Most of you are probably familiar with the Notes factbox present on many pages (often you need to show the factbox).Ā  I was pleasantly surprised to see that Notes existed on both the General Journal and General Ledger Entry Pages.Ā  Then I was unpleasantly surprised when I realized they do not work.Ā  General Journal lets you add Notes to a line but when you post the Journal the Note does not get carried to the G/L Entry.Ā  Even worse the Note remains attached to the General Journal Line when you enter a new line (it never gets deleted).Ā  My next hope was to at least be able to enter Notes directly against a G/L Entry but that doesn’t work either because the General Ledger Entry Page (Page 20) has the Editable property = No which means Notes can only be viewed but not edited.Ā  That’s it for bad news, the rest is all really good.Ā  I have confirmed this is the behavior in NAV 2016 and NAV 2018.
      A few quick mods will make this all work.
      To make the General Journal Notes move to the G/L Entry Notes you need to create a subscription event and add 2 lines of code as seen here:
      Codeunit 12 OnBeforeInsertGLEntryBuffer
      Next if you want to be able to add Notes directly to a G/L Entry there are some properties you need to change on Page 20:
      • Editable = Yes
      • InsertAllowed = No
      • DeleteAllowed = No
      • Set the Editable property of each field to No (no picture for this)
      The real trick on this one is to have AllowModify = Yes (but make the field controls not editable) which makes the factbox allow a user to “Click here to create a new note”.Ā  These mods take a total of 10 to 15 minutes but to me are well worth the effort.Ā  I could envision this on any other Journal/Ledger Entry combo as well such as Item Journal/Item Ledger Entry (Customer Ledger and Vendor Ledger work since the pages are already editable so you can modify a few of the fields such as Due Date).
      Microsoft if you see this I would totally consider adding this to base (barely any effort as seen above).Ā  Another solution might be to change the behavior of Notes to allow you to add a Note even when a Page is not Editable.Ā  This would allow the second mod mentioned above to go away and allow this to work on every Ledger Entry page plus a few others (such as page 5076 Interaction Log Entries).
      Jason Wilder
      Senior Application Developer
      Stonewall Kitchen
      York ME
    • Jason Wilder
      October 10, 2018 at 10:36 AM
      Just want to add 2 things:
      1) By doing the changes listed above this will make Links work in the same manner as well.
      2) Currently the second mod above (Add a Note or Link directly while on a G/L Entry) is not doable in AL as Page Extension objects do not provide access to the Editable, InsertAllowed or DeleteAllowed properties.
      Jason Wilder
      Stonewall Kitchen
      York ME
    • Ramin Marghi
      October 15, 2018 at 2:02 PM
      Hi Jason,
      As an accountant I can appreciate the general theory behind this, however as a consultant I strongly adviseĀ againstĀ any specific related records on the G/L Entry records themselves (where the Primary Key is “Entry No.”). I’ve actually talked a few people off this ledge in the past.
      Instead, my general recommendation isĀ if you absolutely must have related records (be it a file link/attachment — which we’ve done a few times, note, etc.) then do it on the G/L Register and not the G/L Entry. This ensures that you’re actually associating the note/document with the entireĀ transaction itself and not just a single G/L Entry record. A good example is if you’re doing post-audit adjustments and want to associate the PDF scan of the auditors’ comments with the transaction — you may have hundreds of lines in there for adjustments that really refer toĀ one source document, so the entire G/L Register is a good spot to associate the note/document with.
      Just my two cents.
      Ramin Marghi , CPA, CGA
      CPA, CGA | ERP Consultant
      Catapult
      VANCOUVER BC
    Jason Wilder replied 8 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Notes on G/L Entry’ is closed to new replies.
