NAV Client Closing
NAV Client Closing
Posted by Heather Walters on March 9, 2020 at 4:55 pm-
#NAV2015 RTC
We have had an influx of reports that users’ NAV clients are closing unexpectedly without warning. Some say it is when they move focus to a non-NAV window. Some say it is when they move their mouse over their task bar. NAV has been working fine for years, despite not technically being supported on Windows 10. ?Do you guys have any ideas? I have also reached out to our NAV partner, but I figured I would also ask here.
Heather Walters
Apothecary Products
Burnsville MN
Anthony Rowan
MemberMarch 10, 2020 at 8:57 AM
Are your users laptop users with external monitors?Ā We had this issue due to the different dpi/resolution of the monitor.ĀThe fix:
- Right-click on the application shortcut
- Select the Compatibility Tab
- Select Change high DPI settings:
- Uncheck Program DPI
- Check “High DPI scaling override” and the drop-down select, “System”
- Click OK and try launching NAV
Anthony Rowan
Ancillare
Horsham PA
Thank you, Anthony! I will give that a try!
Heather Walters
Apothecary Products
Burnsville MN
We have also encountered this and found that updating our docking station firmware fixed the problem (Windows 10/Lenovo docks).
Teri Chow
Business Applications Manager
Second Harvest of Silicon Valley
San Jose4082668866
Ken Elliott
MemberMarch 13, 2020 at 10:09 AM
We have the same issue in NAV 2013, and Anthony’s solution does work. However, be aware that compatibility mode could affect your print alignment if you print directly to forms. We have found that we must turn off the compatibility mode prior to printing our accounts payable checks in order for the alignment to be correct.——————————
Ken Elliott
Director, Financial Operations
Billy Graham Evangelistic Association
Charlotte NC
Jimmy Yu
MemberMarch 12, 2020 at 9:56 AM
We’ve also experienced this, but very limited.Ā So far, only 2 users plus myself have reported this.Ā It started happening after we switched to Windows 10.Ā The problem will only happen for a few hours and then just go away.Ā Our partner had suggested to stop using multiple monitors with the docking station but that’s just not possible.I’d be interested in hearing if this has happened to others in the community.
Jimmy Yu
Enterprise Architect
Step Energy Services Inc
AB
Ryan Ketterling
MemberMarch 13, 2020 at 9:23 AM
I would suggest looking at the Windows update log and see about rolling back updates to before the issue started.Ā My guess is there is an update that has caused the problem.——————————
Ryan Ketterling
Minneapolis MN
Yes, we’ve seen this. Not specific to NAV that we know of, but since NAV is open all day long on the client workstations it’s hard to say with certainty. We seem to do ok with laptops and 2 monitors but 3 becomes unpredictable. We finally gave up after much work to resolve the issue. We are a Dell house with all Dell equipment. I do not see that the brand or type of monitor or the docking station/laptop updates have made a consistent difference.
I myself am running 3 mismatched monitors on a laptop reliably, but am almost never in NAV for more than a few minutes at a time. Interpret that as you see fit.
Best Regards,
Devora Locke
IT Helpdesk Analyst
Shin-Etsu MicroSi
——Original Message——
Jimmy Yu
AB
Heather Walters replied 6 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘NAV Client Closing’ is closed to new replies.
