NAV C/AL Coding Question – Lookup on a Report Request Page
  • NAV C/AL Coding Question – Lookup on a Report Request Page
    Posted by Lewis Rosenberg on March 9, 2018 at 11:55 am
      March 9, 2018 at 11:55 AM
      Hi Everyone.
      I could use some C/AL help.
      I have a table and the first two fields, SubjectID (Code 20) and Issue (Text 20), make up the Key.
      So the data might look like this:
      SubjectIDĀ Ā  Issue
      SOP-100Ā Ā Ā Ā  New
      SOP-100Ā Ā Ā Ā  1
      SOP-100Ā Ā Ā Ā  2
      I have a report with a request page. On the request page, there is a lookup to the table to select the SubjectID and Issue.
      The lookup places only the value of the SubjectID into the lookup variable. How can I get it to also grab the value of the Issue field?
      #NAV2013R2
      #DeveloperorDBA
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Franz Kalchmair
      March 9, 2018 at 4:16 PM
      your table’s is e.g. table50000.
      add a list page on base of that table, add the object no. of the page in table propertiesĀ LookupPageID,DrillDownPageID.
      in the request page you use a glob. var. e.g.Ā subid. in the req. page line do not set a table relation.
      add following code in theĀ subid – OnLookup trigger:
      IF PAGE.RUNMODAL(0,table50000) = ACTION::lookupok THEN
      subid := table50000.SubjectID + ‘-‘ + table50000.Issue;
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Vienna, Austria, Europe
      March 12, 2018 at 10:30 AM
      ?Thank you !
      That was a great help.
    • Val Gameiro
      March 12, 2018 at 10:42 AM
      When you’re looking up on a field, you can only retrieve one value, hence the code workaround.
      Another option, although perhaps not as elegant, would be to add a combination field that takes both values of the key into itself, and that’s the field you would look up on (if that makes any sense).
      This is a common trick I use in PowerPivot tables or even Jet Reports sometimes.
      Val Gameiro
      Advanced Business Systems, LLC
      Implementer/Project Manager
      Austin, Texas
      former NAVUG Austin Chapter Leader
    Lewis Rosenberg replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘NAV C/AL Coding Question – Lookup on a Report Request Page’ is closed to new replies.
