NAV 2018 System Requirements
  • NAV 2018 System Requirements
    Posted by Ronald L McVicar Jr on June 3, 2019 at 11:46 am
    • Ronald McVicar
      June 3, 2019 at 11:46 AM
      We are getting ready to configure our NAV 2018 environment; and so what is stable and working?
      How about Windows Server 2019 Datacenter?
      This will be for two separate servers:Ā  Application (Service Tiers); and Web; and the SQL Server
      We are about 40 users
      And for SQL I suspect that SQL Server Standard Edition 2017 should be fine that what is everybody choosing for NAV 2018 on premise?
      NSP (Quality Meats)
      nspproteins.com
    • Gaurav Raj
      June 4, 2019 at 8:30 AM
      Hi Ronald,
      NAV 2018 environment can be deployed on Windows 2019 Standard + SQL Server standard 2017.
      Windows Datacenter edition is used in case you need more than two virtual machines to be provisioned on the same hardware. Ā
      NAV 2018 on-premise environment has the following components:
      1.Ā Ā Ā Ā Ā Ā  NAV Application Server
      2.Ā Ā Ā Ā Ā Ā  NAV Database Server
      3.Ā Ā Ā Ā Ā Ā  Web Server – can be on application or on different server places in DMZ
      4.Ā Ā Ā Ā Ā Ā  SSL certificate to be deployed on web server for securing the connectivity and accessing the application using mobile
      Not to miss, the configuration of above components play an important role, which should be based on the transaction volume and number of concurrent users.
      Gaurav Raj
      AlleTechnologies Inc.
      McLean
    Ronald L McVicar Jr replied 7 years, 5 months ago 1 Member · 0 Replies
The discussion ‘NAV 2018 System Requirements’ is closed to new replies.
