MPS/MRP
  • Posted by Catherine Collins on December 7, 2017 at 11:19 am
    • Catherine Collins
      December 7, 2017 at 11:19 AM
      ?We are on NAV 2015 and implementing MPS/MRP.
      Is itĀ  possible to run just MRP (uncheck the MPS box) and have it calculate the demand requirements to include Sales FORECAST along with planned demand and any setups we have for the Reorder Policies?Ā Ā Ā  Or do you have to check both boxesĀ  (MPS & MRP) for MRP to include the demand for Sales Forecast in the calculations for MRP ?
      Catherine Collins
      Business System Analyst
      San Francisco Bay Coffee Company
      Lincoln CA
    • Gregory Alford
      December 8, 2017 at 9:31 AM
      If you are populating the “Production Forecasts” in NAV (this option is on the Manufacturing Planning menu) and you want to use the forecast as part of your MRP calculation, you would check MPS. If you do not want to include those entries you would uncheck the MPS. If you are not populating the “Production Forecasts”, it really doesn’t matter whether MPS is checked or unchecked.
      Gregory Alford
      ERP Manager
      Tri Star Metals LLC
      Carol Stream IL
    • Andrew Good
      December 11, 2017 at 7:38 AM
      ?Further to Greg’s notes. The Sales Forecast (Item Budget) is different from the Production Forecast. The Production Forecast is where you need to record your forecast to be available to the Planning Worksheet. The Production Forecast is part of your independent demand and will be picked up when you run MPS (Master Production Schedule).
      Andrew Good
      President
      Liberty Grove Software
      Oakbrook Terrace IL
    • Jenn Claridge
      December 18, 2017 at 10:55 AM
      Also to the point of the gentlemen, when running the planning worksheet, “Calculate Plan”Ā you need to ensure you have selected the populated forecast ?in the “Use Forecast” field.
      Jenn Morton
      Manufacturing Consultant
      Sabre Limited
      Cambridge
    Catherine Collins replied 8 years, 10 months ago 1 Member · 0 Replies
The discussion ‘MPS/MRP’ is closed to new replies.
