Move Tag
  • Posted by Chris-Soraparu on January 26, 2018 at 11:45 pm
    • Chris Soraparu
      January 26, 2018 at 11:45 PM
      Is there a way to move a tag that has been allocated to a sales order or a RPO without unallocating it first?
      Chris Soraparu
      Tri Star Metals LLC
      Carol Stream IL
    • Val Gameiro
      January 29, 2018 at 10:06 AM
      ?I’m not familiar with Tags in NAV, do you mean Dimension? Or is this something in a newer version of NAV?
      I’m on 2013 R2, and we do not have tags.
      If you mean a Dimension, so long as the SO hasn’t been posted, you can change the Dimensions at will. Once it’s Shipped you might end up with discrepancies, once it’s Invoiced you can’t change it.
      On a Return PO, if the Dimensions don’t match the PO, you may also end up with discrepancies.
      But I’m assuming Tags are something else and my response isn’t applicable to you.
      Sorry I can’t be of more help, if that’s the case.
      Val Gameiro
      Senior NAV Analyst
      BPL Plasma Inc.
      Austin, Texas
      NAVUG Austin Chapter Leader
    • Kim Dallefeld
      January 29, 2018 at 2:45 PM
      Val, I think tags are lots for this user.
      Kim Dallefeld
      VP Professional Services
      Syte Consulting Group
      kdallefeld@sytecg.com
      Past NAVUG Board Chairman
      NAVUG Programming Committee
    • Chris Soraparu
      January 30, 2018 at 8:17 AM
      Is there a way to move a LOT or change it’s location that has been allocated to a sales order or a RPO without unallocating it first?
      Chris Soraparu
      Tri Star Metals LLC
      Carol Stream IL
    • Val Gameiro
      January 30, 2018 at 8:48 AM
      Sorry for my ignorance.
      Once it is reserved, I believe you have to take out of the Reservation entries, then move it, and then put it back on the order.
      If NAV even let you move it, it wouldn’t update the Reservation Entry from the journal.
      Val Gameiro
      Senior NAV Analyst
      BPL Plasma Inc.
      Austin, Texas
    Chris-Soraparu replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Move Tag’ is closed to new replies.
