Looking up Item availability
  • Looking up Item availability
    Posted by Chris-Soraparu on January 19, 2018 at 8:53 am
    • Chris Soraparu
      January 19, 2018 at 8:53 AM
      Can anyone suggest a more efficient way to look at individual tags in inventory as well as items on order or in production on the same screen? Right now I can see a summary of total pounds & whats on order when I’m in the “Items” screen. However, to see info on an individual tag I have to drill down through 2 screens.  Once I drill down to the Lot No. Information List I lose the ability to see whats on order. Ideally I would like to have a screen that shows me individual tag line with the Supply & Demand Fact Boxes on the side.
      Chris Soraparu
      Tri Star Metals LLC
      Carol Stream IL
    • Kim Dallefeld
      January 19, 2018 at 10:09 AM
      Chris, when you say ‘tag’ do you mean ‘lot’? And what version on NAV are you running?
      To see what’s on order by lot number you will need a customization page/screen.
      Kim Dallefeld
      VP Professional Services
      Syte Consulting Group
      kdallefeld@sytecg.com
      Past NAVUG Board Chairman
      NAVUG Programming Committee
    • Chris Soraparu
      January 19, 2018 at 12:18 PM
      I am on NAV 2017.
      I guess “lot” and “tag” would be the same. We are a metal distributor and everything in our system is broken down to individual bundles/tags.
      Chris Soraparu
      Tri Star Metals LLC
      Carol Stream IL
    • Jenn Claridge
      January 19, 2018 at 12:27 PM
      ?Hi Chris
      Could you add a flow field to the Lot No. information page to see the supply and demand information?
      You’d still have to do the drilling if you don’t want a custom page I believe.
      Jenn Morton
      Manufacturing Consultant
      Sabre Limited
      Cambridge Ontario
      Canada
    • Adam Jones
      January 22, 2018 at 2:48 AM
      Hi Chris,
      You said in your post “Ideally I would like to have a screen that shows me individual tag line with the Supply & Demand Fact Boxes on the side.” Have you thought of doing it the other way around as this is part of base NAV, though you may have to ask your developer to link it.
      There is a factbox (9126 – Lot Numbers By Bin Factbox) that shows the bin content, by lot number for a location.
      This would show you all the information for the line you have selected without drilling through if you had it on the item list.
      Many thanks.
      Adam Jones
      Celebration Paper & Plastics Ltd
      Burton upon Trent
    • Ben Baxter
      January 22, 2018 at 8:36 AM
      Adam has a great suggestion.  If you need to see the Lot information, the fact box is your best bet to avoid drilling down into multiple screens.
      If the Lot information was not required, there are add-on products that provide clean Supply & Demand fact boxes to show, and allow access to, the different sources impacting an Item.
      Ben Baxter
      Consultant
      Accent Software, Inc.
      Carmel IN
    • Jason Nicolaou
      January 22, 2018 at 8:23 AM
        Please see supply & demand discussion here.  Good luck.?
      Jason Nicolaou
      Solutions Architect
      Velosio
      Dublin OH
    • Jason Wilder
      January 22, 2018 at 11:24 AM
      Jason, I do not think your link worked.
      Jason Wilder
      Senior Application Developer
      Stonewall Kitchen
      York ME
    Chris-Soraparu replied 6 years, 12 months ago 1 Member · 0 Replies
The discussion ‘Looking up Item availability’ is closed to new replies.
