Lanham E-Ship prints multiple Packing Lists
Posted by Noreen Fujita-Sacco on November 28, 2018 at 5:47 pm-
Hello, all.Ā I can’t remember if/where there is a setting to tell E-Ship how many copies of a document to print. We’re in NAV 2018. Thanks!
Noreen Fujita-Sacco
Applications Coordinator
Gear Aid Inc.
Bellingham WA
360-392-2703
noreen.fujitasacco@gearaid.com
ReBecca Wadsworth
MemberNovember 29, 2018 at 10:51 AM
Hi NoreenĀUnfortunately, there isn’t anywhere to set a number of copies to print. Everything prints one copy.Ā
ReBecca Wadsworth
Norcross GA
Pratik Patel
MemberNovember 29, 2018 at 11:57 AM
Noreen,We are in NAV2016 and the following worked for us. Go to the PC that is used for printing the packing list and login as the User ID for shipping. Go to Posted Sales Shipment, and click Print for any Shipment. The Edit-Sales Shipment window will pop-up to allow for you to select options for printing the Packing List. There is a field “Number of Copies” which probably has a zero in it. Change that to 1. Then click Print button at the bottom. Two copies of the Packing List should have printed. NAV should now remember that a 1 was entered in the Number of Copies field. If you go back to manually printing any previous Posted Sales Shipment, you should see the 1 in the field. Now, when processing new shipments via Lanham on that PC and User ID, two Packing Lists should automatically print out.
Pratik Patel
Symbex Companies
Thank you, Pratik. That works to increase the number of copies. However, if the setting is one and we receive two printouts, we’re unable to set to zero to receive only one printout. Do you know of a way to change to print only one?
Noreen Fujita-Sacco
Gear Aid Inc.
Bellingham WA
360-392-2703
Pratik Patel
MemberDecember 5, 2018 at 11:38 AM
Noreen, do you mean having the ability to change how many copies to print while doing Lanham Pack Line? If so, I am not aware of a way to do it during the Pack Line steps. To default back to one copy printed at all times, the steps I mentioned above can be followed again and enter zero into the Number of Copies field. Hope that makes sense.——————————
Pratik Patel
Symbex Companies
Noreen Fujita-Sacco replied 7 years, 11 months ago 1 Member · 0 Replies -
The discussion ‘Lanham E-Ship prints multiple Packing Lists’ is closed to new replies.
