Label Printing From within NAV
Posted by Meenakshi Singh on June 19, 2017 at 9:50 am-
Hello,Ā
We are using the
Loftware Ā label system to integrate with NAV to print different Case labels. AlthoughLoftware Ā product looks good and prints Labels< I am finding it hard to work with theĀ NAV integration part. Having difficultiesĀ printing in different/multiple languages as well as some accented characters and trademarks. They just don’t printĀ accurately when data is coming in from NAV.Does anyoneĀ have any experienceĀ working with it? What are other good add-ons or external products availableĀ for Label printingĀ that Integrate well with NAV?Ā
Thanks for your guidance in advance,
Meenakshi——————————
Meenakshi Singh
Home Market Foods, Inc.
Norwood MA
Meenakshi – What version of NAV are you using?
Gregory Alford
ERP Manager
Tri Star Metals LLC
Carol Stream IL
NAV 2013
Meenakshi Singh
Norwood MA
Great – then you might want to consider BarTender from Seagull Software. When we needed to integrate label printing, we were able to get a local reseller to do the customizations for us. Seagull also has better printer drivers than the printer manufacturers.
Gregory Alford
ERP Manager
Tri Star Metals LLC
Carol Stream IL
Jan Penkava
MemberJune 20, 2017 at 3:42 AM
Hi Meenakshi,not sure how complex your requirements are, but we have solved all our labeling needs by using standard NAV report and free .NET library Zxing which supports all kinds of different barcode types. Availablat at Github :Ā zxing/zxing
A simple example is hereĀ Creating QR Code in NAV 2016
In our solution we do not save the file every time, just use function to pass it back to the report
Hope this helps!——————————
Jan Penkava
United Cast Bar UK Ltd.
Chesterfield
Hi Jan,Our requirementsĀ are a little bit more complicated than just designing it in NAV.Ā
For a simple one time design, you are right, designĀ a NAV report would work best.Thanks,
Meenakshi——————————
Meenakshi Singh
Norwood MA
Thanks, Greg, I will review that software. Do you have feedback on how easy it is for an end user to design a label in that software?Ā I wouldĀ like to get my IT team out of designingĀ every label. Ā My ideal scenario wouldĀ be to design templates for them and then users can copy those template and make other minor changes to label as needed.
Meenakshi Singh
Norwood MA
I had the vendor that sold us Bar Tender design one label for each automotive customer. From then on I copied and modified additional labels as necessary. Hope that helps.
Gregory Alford
ERP Manager
Tri Star Metals LLC
Carol Stream IL
Berlinda Yap
MemberJune 22, 2017 at 9:44 AM
?We are using Bar Tender from Seagull – we train our users to use it so that they can design if need to or modify the template label IT created.It is fairly easy for user to pickupĀ once they are aware of what fields they need to modify.
Berlinda Yap
IS Service Manager
Foremost Groups, Inc.
East Hanover NJ
Berlinda Yap
MemberJune 22, 2017 at 9:47 AM
?We integrated our packing slip with Bar Tend for one customer who needs to have a barcode on the packing slip to handle returns to their store.
What we did is export the order information and integrate the file into Bar Tender using the Database option and design the layout in Bar Tender and what information need to be in bar code format.Our warehouse is modifying labels for a customer that always has different sku numbers on their orders to stick to the boxes.
Berlinda Yap
IS Service Manager
East Hanover NJ
This is good information, thank you so much for sharing your experience with BarTender.
Meenakshi Singh
Norwood MA
Meenakshi Singh replied 8 years, 8 months ago 1 Member · 0 Replies -
The discussion ‘Label Printing From within NAV’ is closed to new replies.
