Item Ledger Entries
  • Item Ledger Entries
    Posted by DSC Communities on September 15, 2022 at 6:34 pm
    • Khan Wajahatullah
      September 15, 2022 at 6:34 PM
      Hello All,
      I have a situation in D365 BC.
      I have spotted an item with item ledger entries in it.
      Upon browsing into entries, I came across an entry number where the remaining qty is zero but the field called Open is ticked, means it says its still open when remaining qty is zero,
      I tried to find out where the entry was applied to from application worksheet but failed to unapply and re apply it as when I tried it says Unapply cannot be done to an Correction Entry.
      What is the way now left in the system for me to make this field Open=NO since that particular entry number has no remaining qty in the system.
      Thank You.
      Rgds
      Khan
      Khan Wajahatullah
      Hydro Style Pte Ltd
      Singapore
    • Ronald McVicar
      October 19, 2022 at 11:01 AM
      Khan
      this article in the Microsoft Dynamics NAV Community might help: Question about Closing Open Item Ledger Entries
      What document(s) are or were involved in the creation of the entry: purchase, fixed assets, manufacturing, etc. or just a Item Journal Entry, etc.? And also understanding your costing method is often important.
      If this is broken or code error then this might be more than a “correction”: Follow these steps in NAV.Ā  Two articles in the in the online resources for Microsoft.com for Dynamics NAV can help if this can be cleaned up:
      How to: Close Open Item Ledger Entries Resulting from Fixed Application in the Item Journal
      How to: Remove and Reapply Item Ledger Entries
      Son on this Item Ledger Entry when you go to “Navigate” from the menu and the window pops up you do not see the related Entries: Posted (e.g., Sales, or some other) or Value Entry, Warehouse Entry, etc.)?
      NSP (Quality Meats)
      nspproteins.com
    DSC Communities replied 3 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Item Ledger Entries’ is closed to new replies.
