Inventory Test Report
  • Inventory Test Report
    Posted by Kim Dallefeld, MVP on December 5, 2016 at 11:18 am
    • Kim Dallefeld
      December 5, 2016 at 11:18 AM
      NAV2016 – Inventory Test Report does not run and it locks NAV. I’ve recompiled and same results. Has anyone seem this problem? Is there a fix?
      Kim Dallefeld
      NAV Consultant
      Ft Worth, TX
      Kim@Dallefeld.com
    • Franz Kalchmair
      December 5, 2016 at 11:36 AM
      do you mean the inventory posting test report? is that report customized ?
      run debugger, check if you have an endless loop.
      also check, if there are flowfields, which need long runtimes.
      also helpful is the sql profiler.
      Franz Kalchmair
      Dynamics NAV Engineer and Consultant
      Microsoft MVP
      Vienna
    • Kim Dallefeld
      December 5, 2016 at 12:15 PM
      Yes, report 702. Nothing custom. Just curious why the standard report will not run.
      Kim Dallefeld
      NAV Consultant
      Ft Worth, TX
      Kim@Dallefeld.com
    • Franz Kalchmair
      December 5, 2016 at 1:10 PM
      then check windows eventlog for error messages and run sql profiler parallel to the report rendering.
      restart nav service, recompile all nav objects.
      export that report as text, remove it from database, import and compile.
      Franz Kalchmair
      Microsoft MVP
      Vienna
    Kim Dallefeld, MVP replied 8 years ago 1 Member · 0 Replies
The discussion ‘Inventory Test Report’ is closed to new replies.
