Getting BC (On Premise) Help Documentation To Work
Posted by Lewis Rosenberg on April 27, 2021 at 9:46 am-
Hello All.Ā Ā
We are running #D365BusinessCentralĀ version 14 on premise.Ā Ā
Does anyone know how to implement the Business Central Help Documentation (ex: clicking the question mark in the top right corner of the client window)?
We upgraded last year and it worked but one day noticed that it stopped working.Ā It appears that it was set up to run from our Upgrade Server instead of our production server.
This is the error that we currently get.Ā It is referencing the wrong server (our upgrade/dev server).
http://www.apifishcare.com
D365UG-BC/NAVUG All-Star
D365UG-BC/NAVUG Board of Advisors, Chairperson Emeritus
Steven Chinsky
MemberApril 28, 2021 at 8:41 AM
Lewis,Not sure if you received the file from the other Forum you posted this on. Here is a copy.
Steve——————————
Steven Chinsky
Manager
Wipfli
Mansfield MA
NAVUG/BC Programming Committee Member
NAVUG All-Star, Granite Award Recipient, MCP, DCMP
Wow, Steve 2722 pages!Ā Thanks.Ā I guess I am all set for my summer reading now. š
Brad Everts
MemberApril 28, 2021 at 11:20 AM
Lewis,Ā I think all you need to do is make a change to the navsettings.json file to include the correct URL.Ā You may also need to go through the application install and modify the setup to include the Help Server, if you didn’t do that initially.Ā I think this link will give you what you need.
Ā https://docs.microsoft.com/en-us/dynamics365/business-central/dev-itpro/deployment/configure-help
Brad Everts
IT Supervisor
Garner Foods
Winston-Salem NC
Thanks Brad.Ā Not quite there yet, but that led me to my ClientUserSettings.config file which had the wrong server URL and Port,
<add key=”HelpServer” value=”SERVER_NAME” />
<add key=”HelpServerPort” value=”49001″ />When I corrected that, the HELP functionality worked.Ā I also fixed the XML file that I use when installing the Windows Client for everyone.
Now if I close the BC Windows client, delete my ClientUserSettings.config, and restart my Windows BC client, the config file is recreated incorrectly.Ā I guess my question now is: where are the settings pulled from when the ClientUserSettings.config is recreated.Ā Is that in a local file of on the service tier?
Brad Everts
MemberApril 28, 2021 at 2:39 PM
Lewis,Ā Did you change the ClientUserSettings.config file just for your user or for all users on your machine?
Ā Here is an article regarding NAV changes to the ClientUserSettings.config file, but it may still apply since you’re on BC14.
https://docs.microsoft.com/en-us/dynamics-nav/configuring-the-windows-client#:~:text=A%20separate%20instance%20of%20the,file%20are%20hidden%20by%20default.What I think might be pertinent to your situation from that article:
Ā “If you want to change default Microsoft Dynamics NAV Windows client settings for all future users on this computer, edit the default ClientUserSettings.config file in C:ProgramDataMicrosoftMicrosoft Dynamics NAV110. You must run your text editor with Administrator permissions when you do this.
If you want to change Microsoft Dynamics NAV Windows client settings for an existing user, edit the ClientUserSettings.config file in that user’s C:Users<username>AppDataRoamingMicrosoftMicrosoft Dynamics NAV110 folder. After you modify a user’s ClientUserSettings.config file, you must restart the Microsoft Dynamics NAV Windows client for changes to take effect.”
Ā Ā Unfortunately, we’re running NAV2018 and testing BC17 so I can’t test this out and report for sure that it works, but I’m hoping it helps. My best guess is if you are deleting the file in your user profile, when you re-open BC, it is grabbing the config from the .config file in the ProgramData folder on the computer.Ā Once again, I’m not 100% sure of that.
Brad Everts
IT Supervisor
Garner Foods
Winston-Salem NC
Yes, fixing the ClientUserSettings.config file in C:ProgramDataMicrosoftMicrosoft Dynamics NAV140 allows the ClientUserSettings.config file in C:Users%USERNAME%AppDataRoamingMicrosoftMicrosoft Dynamics NAV140 to be regenerated correctly.
So now the challenge is how to fix this for all of the users.Ā I was hoping this information was being pushed from the server, but it appears that is not the case.
Brad Everts
MemberApril 28, 2021 at 3:53 PM
Lewis,Ā I’m glad that worked.Ā As far as copying the file to all of the local computers, that will be dependent on your network setup, but a logon script that copies the file from a shared folder location to the local computer would work.
Brad Everts
IT Supervisor
Garner Foods
Winston-Salem NC
Lewis Rosenberg replied 4 years, 4 months ago 1 Member · 0 Replies -
The discussion ‘Getting BC (On Premise) Help Documentation To Work’ is closed to new replies.
