General posting setup
Posted by Michael-Carr on August 3, 2018 at 5:11 pm-
in NAV2018 CU6
to load the table and start making changes +3 minutes
in NAV2013R2Ā
Same table no changes , no mods = less than 3 seconds
Anybody have a clue as to why this would happen? I looked at 6 columns have disappeared so MS changed the table.Ā
I am being told that the same think happened in 2017 and MS took 17 update cycles to fix.
Michael Carr
VP , Finance
Philadelphia Scientific LLC
Montgomeryville PA
Cynthia Priebe
MemberAugust 6, 2018 at 1:58 PM
Michael,ĀGood question.
There is a new field “Used in Ledger Entries” – CalcFormula Count(“G/L Entry” WHERE (Gen. Bus. Posting Group=FIELD(Gen. Bus. Posting Group),Gen. Prod. Posting Group=FIELD(Gen. Prod. Posting Group))).Ā
When checking keys on GL Entries, I don’t see one including these posting groups.Ā Could this be the source of your problem?
The databases I checked don’t seem to have a performance issue, but maybe the volume of data isn’t comparable to yours.
Maybe one of the developers that monitors this forum can add their 2 cents.
Cynthia Priebe, MCTS, DCP
Liberty Grove Software
Cynthia you definitely nailed it.Ā A couple of quick solutions:
1) Create a key in table 17 that is (Gen. Bus. Posting Group, Gen. Prod. Posting Group)
or
2) If you do not care about this field (you probably do not need it, seems like a nice to have only) simply remove it from Page 314 “General Posting Setup” and Page 395 “General Posting Setup Card”. You can try just hiding it on these pages but pretty sure the field will still calculate if you do this.I would go with #2.
Jason Wilder
Senior Application Developer
Stonewall Kitchen
York ME
Thank you,Ā Jason , for the tech fix,
We indeed choose option #2 , and it now loads in 5 seconds.
Thank you again and you get 50 points for the house of Wilder.
Michael Carr
VP , Finance
Montgomeryville PA
andĀ 50 points to the house of Priebe for meritorious service to Hogwarts.
Thanks , Cynthia , you hit the mark with that one.Ā
We removed the field and now it pops up in 15 seconds.
Thank you for help.
Michael Carr
VP , Finance
Montgomeryville PA
Cynthia Priebe
MemberAugust 7, 2018 at 10:00 AM
Thank you Mark, my daughter will be so proud of me šGlad I could help.
Michael-Carr replied 8 years, 1 month ago 1 Member · 0 Replies -
The discussion ‘General posting setup’ is closed to new replies.
