Enable Encryption on SQL Server Connection
  • Enable Encryption on SQL Server Connection
    Posted by Lewis Rosenberg on August 1, 2017 at 4:33 pm
      August 1, 2017 at 4:33 PM
      Has anyone turned this setting on for their NAV instance?Ā Ā  I was asked to see what the result would be and once I turned it on (for our test system), I could no longer connect my client.Ā  Each time I tried, the server instance stopped running.
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Ian Ray
      August 1, 2017 at 6:30 PM
      You will need to install the encryption key from the NAV Powershell cmdlet, e.g.Ā New-NAVEncryptionKeyĀ  -KeyPath “C:UserDataSQLKeyMySQLKey” -Password (Get-Credential).Password
      Full instructions
      Configuring SQL Server Authentication in Microsoft Dynamics NAV 2016 – Part-1
      Ian Ray
      Cypress Grove
      Arcata CA
    • Mark Miranda
      August 2, 2017 at 12:07 PM
      Hi Lewis,
      You should not need an encryption key to encrypt the connection, but you do need to have SSL enabled on the protocols for the server in the SQL Configuration Manager.
      https://technet.microsoft.com/en-us/library/ms189067(v=sql.105).aspx
      Once enabled, you can test this with SQL Server Management Studio to see if it’s working before you attempt to have NAV connect to it. Ā On the Connect to Server window when SSMS starts up, click on Options, and then on the Connection Properties tab, check the “Encrypt Connection” box.
      Mark Miranda
      Director of Information Technology
      Western Computer
    Lewis Rosenberg replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Enable Encryption on SQL Server Connection’ is closed to new replies.
