Dimension Value Type Begin/End Total
  • Dimension Value Type Begin/End Total
    Posted by Noreen Fujita-Sacco on September 17, 2020 at 7:33 pm
    • Noreen Fujita-Sacco
      September 17, 2020 at 7:33 PM
      Hello, all.
      We’re using Totaling in Dimension Value Types in Dynamics NAV 2018. For example:
      010 OEM Begin-Total
      010-01 OEM Key Accounts
      010-02 OEM Other Accounts
      010-99 OEM End-Total (totalling 010..010-99)
      We’re finding that staff setting up new customers occasionally use the 010 OEM code rather than one of the sub-codes. I can set a block on the code which pops an alert when it’s selected on a Customer card. However, I wonder whether that will affect anything when using these subtotals for analysis.Ā
      Has anyone tried this and know what will result?
      Noreen Fujita-Sacco
      Applications Coordinator
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
      noreen.fujitasacco@gearaid.com
    • Jenifer Elliott
      September 18, 2020 at 10:59 AM
      Hi Noreen,
      You should setup Dimension Combinations for this to stop the errors from happening.Ā  This does not stop analysis but prevents the users from using bad combination of dimensions.
      Jenifer Elliott
      Senior Application Consultant
      Technology Management Concepts
      807 Parkview Drive North, Suite 150
      El Segundo, CA 90245
      Phone: 831.277.3280
      Email: jelliott@tmc-la.com
      Website: http://www.abouttmc.com
      September 18, 2020 at 11:15 AM
      Thank you, Jenifer.Ā
      I’ll read through that set-up. I was hoping the block would work since it’s much less complicated.
      Noreen Fujita-Sacco
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
    • Mary Carrero
      September 18, 2020 at 4:38 PM
      If you put the dimension value type to begin total and end total they shouldn’t be able to use it in a transaction.
      Mary Carrero
      Velosio
      apopka NJ
    Noreen Fujita-Sacco replied 6 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Dimension Value Type Begin/End Total’ is closed to new replies.
