December Tips & Tricks
  • December Tips & Tricks
    Posted by Holly Kutil on December 1, 2017 at 8:39 am
    • Holly Kutil
      December 1, 2017 at 8:39 AM
      Freeze Pane
      Using the freeze pane on list view’s is a quick add to any list.Ā  Simply right click on the column header and select choose columns.Ā  To the right of the Show columns in this order:Ā  you will see add freeze pane.Ā  Click on the Add Freeze Pane icon to add it to your columns and place it after the columns you want frozen when you scroll
      Real Estate in NAV
      To increase the amount of space on your screen in NAV you can hide the Ribbon using Ctrl + F1; you can hide the Fact boxes using Alt + F2; You will use the same combinations to reverse the process
      Aero Snap desktop windows
      One of the most appealing aspects of Windows 8 and above touch-friendly side is its ability to “Snap” multiple open apps side-by-side.Ā  The feature comes in very handy on the desktop as well if you need to start multitasking.Ā  Simply click and open window and drag it to the left or right edge of the screen to automatically resize it to fill that half of the desktop.Ā  Dragging a window to the top edge expands it to full screen.
      If you’re more into keyboard commands, windows key + left arrow, Windows key + right arrow, and Windows key + up arrow snaps the selected window in the same manner.
      DIY keyboard shortcuts
      Windows has a ton of keyboard shortcuts baked right in, but you can roll your own to open the software of your choice lickety-split-no mouse-clicking or launcher-hunting required.
      Right-click the program’s launch icon and select Properties.Ā  Open the Shortcut tab, then click in the “Shortcut key” field and press the key you want to use to launch the program.Ā  Windows will assign Ctrl + Alt + <key of your choice> as a keyboard shortcut to open the program.Ā  It’s a seriously useful trick, especially if you don’t want to stuff your taskbar full of quick-launch program icons.Ā  Don’t forget to click OK when you’re done to save the shortcut.
      Holly Kutil ~ NAVUG All-Star
      Solon, OH 44139
      **Great Lakes Chapter**
      ?? Women In Dynamics ??
    Holly Kutil replied 8 years, 11 months ago 1 Member · 0 Replies
The discussion ‘December Tips & Tricks’ is closed to new replies.
