Customize Navigation Pane
  • Customize Navigation Pane
    Posted by Roland-Schenk on April 19, 2017 at 9:26 am
    • Roland Schenk
      April 19, 2017 at 9:26 AM
      How to I set one up and then add function to them in Nav 2017.
      Roland Schenk
      DELCATH SYSTEMS
      Queensbury NY
    • Suresh Kulla
      April 19, 2017 at 9:53 AM
      Roland,
      To customize the navigation pane, you can right-click on the Navigation page and go to Customize Navigation Pane, this will allow you to arrange the items between the departments.
      If the Item you want to add is not available then you need to make sure you to add that first to the Menusuite by using Company/Partner Menusuite and then compile all the menu suites.
      Please check the below blog for more information
      Customize the Navigation Pane in NAV 2013 and Beyond
      Suresh Kulla
      NAV Technical Architect
      ArcherPoint Inc.
      Atlanta GA
    • Ramin Marghi
      April 19, 2017 at 11:33 AM
      Hi Roland,
      Just want to add that the navigation pane itself really only supports ListĀ  pages to be displayed in the main “body” window. I’ve (reluctantly) put Card pages on there before, but it’s really not pretty and doesn’t function very well. I know for some Classic client users, moving to RTC posed a bit of a challenge because they didn’t have a “shortcuts” tab, so I wrote a quick blurb about the navigation pane/ribbon model in a post here: Customize the Navigation Pane in NAV 2013 and Beyond.
      Just a bonus tidbit: What shows up there by default is dictated by what Profile that the user is on — or more specifically, what Role Center pages they’ve been assigned. There’s a whole section called “HomeItems” in that page’s design that contains all the navigation pane items:
      Let us know if you have any issues getting this working for you.
      Ramin Marghi , CPA, CGA
      NAV Finance Consultant
      Catapult
      VANCOUVER BC
    Roland-Schenk replied 9 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Customize Navigation Pane’ is closed to new replies.
