Costed BOM report
Costed BOM report
Posted by DSC Communities on December 29, 2016 at 1:54 pm-
Mark Snyder
MemberDecember 29, 2016 at 1:54 PM
This is the first time I am posting a question so let me know if you need more information.
I looking for a way to print out or export a report that has all of our BOM exploded and the cost associated with all components. We are running NAV 2015 Version 8.0 and we are running a FIFO inventory valuation.
Mark Snyder
FreeBird Chicken
Fredericksburg PA
Take a look at the “Rolled-up Cost Shares” report. You can search for it or go to Departments/Manufacturing/Costing/Reports. It will show the exploded BOM with item costs and capacity costs. Be aware of the levels to help with the roll up. For instance, level one lines will roll up to the item cost. The higher level numbers roll up to their respective parent.
Dave Wiser
Beckwith & Kuffel
Seattle WA
I should also note that the rolled up cost shares is based on the unit cost of the standard BOM. If you are looking at each production run and the costing of each output, you will need to look at the Prod. Order – Detailed Calc. report for the production order.
Dave Wiser
Beckwith & Kuffel
Seattle WA
Mark Snyder
MemberJanuary 3, 2017 at 8:13 AM
I’m getting an error message “The maximum number of BOM levels, 50, was exceeded. The process stopped at item number FGC001310, BOM header number FGC000046, BOM level 5.”
I tried to copy the error box into the reply but it will not copy.
Mark Snyder
FreeBird Chicken
Fredericksburg PA
Assuming that you don’t really have a BOM structure that extends to 50 levels, this error usually occurs when you have looping in your BOM structure. In other words, item A is consumed to make item B, and item B is used to create item A. There may be a couple levels in between but the concept is the same. Check your structure to be sure you’re not consuming an item produced later in the process.
Dave Wiser
Beckwith & Kuffel
Seattle WA
Devang Mehta
MemberDecember 29, 2016 at 3:52 PM
Hi Mark,
You can do this from the Item Card by running the BOM Cost share distribution report. It can be viewed interactively, or printed.
From the Item card, click on the cost shares action (see picture) , then on the BOM Cost share distribution report. To view the interactive way, click Expand All. Scroll to the right and you will see full breakdown of cost by type.
Have Fun
Devang Mehta
NAV Practice Manager
InterDyn BMI————————————————————————-
Rick Dill
MemberDecember 30, 2016 at 8:44 AM
HI Mark, try the Rolled-Up Cost Shares report. You can search for it in the Search box, find it on the item card ribbon, or find it using the following path:
Departments–>Manufacturing–>Costing, then look under the Reports and Analysis section.
Rick Dill
Consultant
ArcherPoint Inc.
Waupaca WI
DSC Communities replied 9 years, 3 months ago 1 Member · 0 Replies -
The discussion ‘Costed BOM report’ is closed to new replies.
