BC environment reference
PHP 8.4.26 - phpinfo() PHP Version 8.4.26
System Linux pod-211154 6.8.0-1055-gke #61-Ubuntu SMP Tue May 26 22:57:42 UTC 2026 x86_64 Build Date Sep 23 2026 06:24:29 Build System Linux Build Provider Perforce Zend (www.zend.com) Server API FPM/FastCGI Virtual Directory Support disabled Configuration File (php.ini) Path /etc/php/8.4-zend/fpm Loaded Configuration File /etc/php/8.4-zend/fpm/php.ini Scan this dir for additional .ini files /etc/php/8.4-zend/fpm/conf.d Additional .ini files parsed /etc/php/8.4-zend/fpm/conf.d/10-mysqlnd.ini, /etc/php/8.4-zend/fpm/conf.d/10-opcache.ini, /etc/php/8.4-zend/fpm/conf.d/10-pdo.ini, /etc/php/8.4-zend/fpm/conf.d/15-xml.ini, /etc/php/8.4-zend/fpm/conf.d/20-bcmath.ini, /etc/php/8.4-zend/fpm/conf.d/20-bz2.ini, /etc/php/8.4-zend/fpm/conf.d/20-calendar.ini, /etc/php/8.4-zend/fpm/conf.d/20-ctype.ini, /etc/php/8.4-zend/fpm/conf.d/20-curl.ini, /etc/php/8.4-zend/fpm/conf.d/20-dba.ini, /etc/php/8.4-zend/fpm/conf.d/20-dom.ini, /etc/php/8.4-zend/fpm/conf.d/20-exif.ini, /etc/php/8.4-zend/fpm/conf.d/20-ffi.ini, /etc/php/8.4-zend/fpm/conf.d/20-fileinfo.ini, /etc/php/8.4-zend/fpm/conf.d/20-ftp.ini, /etc/php/8.4-zend/fpm/conf.d/20-gd.ini, /etc/php/8.4-zend/fpm/conf.d/20-gettext.ini, /etc/php/8.4-zend/fpm/conf.d/20-gmp.ini, /etc/php/8.4-zend/fpm/conf.d/20-iconv.ini, /etc/php/8.4-zend/fpm/conf.d/20-igbinary.ini, /etc/php/8.4-zend/fpm/conf.d/20-imagick.ini, /etc/php/8.4-zend/fpm/conf.d/20-imap.ini, /etc/php/8.4-zend/fpm/conf.d/20-intl.ini, /etc/php/8.4-zend/fpm/conf.d/20-ldap.ini, /etc/php/8.4-zend/fpm/conf.d/20-mbstring.ini, /etc/php/8.4-zend/fpm/conf.d/20-msgpack.ini, /etc/php/8.4-zend/fpm/conf.d/20-mysqli.ini, /etc/php/8.4-zend/fpm/conf.d/20-pdo_mysql.ini, /etc/php/8.4-zend/fpm/conf.d/20-pdo_sqlite.ini, /etc/php/8.4-zend/fpm/conf.d/20-phar.ini, /etc/php/8.4-zend/fpm/conf.d/20-posix.ini, /etc/php/8.4-zend/fpm/conf.d/20-readline.ini, /etc/php/8.4-zend/fpm/conf.d/20-redis.ini, /etc/php/8.4-zend/fpm/conf.d/20-shmop.ini, /etc/php/8.4-zend/fpm/conf.d/20-simplexml.ini, /etc/php/8.4-zend/fpm/conf.d/20-soap.ini, /etc/php/8.4-zend/fpm/conf.d/20-sockets.ini, /etc/php/8.4-zend/fpm/conf.d/20-sqlite3.ini, /etc/php/8.4-zend/fpm/conf.d/20-ssh2.ini, /etc/php/8.4-zend/fpm/conf.d/20-sysvmsg.ini, /etc/php/8.4-zend/fpm/conf.d/20-sysvsem.ini, /etc/php/8.4-zend/fpm/conf.d/20-sysvshm.ini, /etc/php/8.4-zend/fpm/conf.d/20-tokenizer.ini, /etc/php/8.4-zend/fpm/conf.d/20-xmlreader.ini, /etc/php/8.4-zend/fpm/conf.d/20-xmlwriter.ini, /etc/php/8.4-zend/fpm/conf.d/20-xsl.ini, /etc/php/8.4-zend/fpm/conf.d/20-zip.ini, /etc/php/8.4-zend/fpm/conf.d/25-memcached.ini PHP API 20240924 PHP Extension 20240924 Zend Extension 420240924 Zend Extension Build API420240924,NTS PHP Extension Build API20240924,NTS PHP Integer Size 64 bits Debug Build no Thread Safety disabled Zend Signal Handling enabled Zend Memory Manager enabled Zend Multibyte Support provided by mbstring Zend Max Execution Timers disabled IPv6 Support enabled DTrace Support available, disabled Registered PHP Streams https, ftps, compress.zlib, php, file, glob, data, http, ftp, compress.bzip2, phar, ssh2.shell, ssh2.exec, ssh2.tunnel, ssh2.scp, ssh2.sftp, zip, s3useast2 Registered Stream Socket Transports tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3 Registered Stream Filters zlib.*, string.rot13, string.toupper, string.tolower, convert.*, consumed, dechunk, bzip2.*, convert.iconv.* This program makes use of the Zend Scripting Language Engine:
Zend Engine v4.4.26, Copyright (c) Zend Technologies with Zend OPcache v8.4.26, Copyright (c), by Zend TechnologiesPHP 8.4.26 - phpinfo()
Configuration
PHP Core
Directive Local Value Master Value allow_url_fopen On On allow_url_include Off Off arg_separator.input & & arg_separator.output & & auto_append_file no value no value auto_globals_jit On On auto_prepend_file /usr/local/share/auto_prepends/auto_prepends.php /usr/local/share/auto_prepends/auto_prepends.php browscap no value no value default_charset UTF-8 UTF-8 default_mimetype text/html text/html disable_classes no value no value disable_functions apache_child_terminate,apache_get_modules,apache_get_version,apache_getenv,apache_note,apache_setenv,disk_free_space,disk_total_space,diskfreespace,dl,exec,fastcgi_finish_request,link,opcache_compile_file,opcache_get_configuration,opcache_invalidate,opcache_is_script_cached,opcache_reset,passthru,pclose,pcntl_exec,popen,posix_getpid,posix_getppid,posix_getpwuid,posix_kill,posix_mkfifo,posix_setegid,posix_seteuid,posix_setgid,posix_setpgid,posix_setsid,posix_setuid,posix_uname,proc_close,proc_get_status,proc_nice,proc_open,proc_terminate,realpath_cache_get,shell_exec,show_source,symlink,system apache_child_terminate,apache_get_modules,apache_get_version,apache_getenv,apache_note,apache_setenv,disk_free_space,disk_total_space,diskfreespace,dl,exec,fastcgi_finish_request,link,opcache_compile_file,opcache_get_configuration,opcache_invalidate,opcache_is_script_cached,opcache_reset,passthru,pclose,pcntl_exec,popen,posix_getpid,posix_getppid,posix_getpwuid,posix_kill,posix_mkfifo,posix_setegid,posix_seteuid,posix_setgid,posix_setpgid,posix_setsid,posix_setuid,posix_uname,proc_close,proc_get_status,proc_nice,proc_open,proc_terminate,realpath_cache_get,shell_exec,show_source,symlink,system display_errors Off Off display_startup_errors On On doc_root no value no value docref_ext no value no value docref_root no value no value enable_dl Off Off enable_post_data_reading On On error_append_string no value no value error_log syslog syslog error_log_mode 0644 0644 error_prepend_string no value no value error_reporting 4983 4437 expose_php Off Off extension_dir /usr/lib/php/8.4-zend /usr/lib/php/8.4-zend fiber.stack_size no value no value file_uploads On On hard_timeout 2 2 highlight.comment #FF8000 #FF8000 highlight.default #0000BB #0000BB highlight.html #000000 #000000 highlight.keyword #007700 #007700 highlight.string #DD0000 #DD0000 html_errors On On ignore_repeated_errors On On ignore_repeated_source Off Off ignore_user_abort Off Off implicit_flush Off Off include_path .:/usr/share/pear/php:/usr/share/php .:/usr/share/pear/php:/usr/share/php input_encoding no value no value internal_encoding no value no value log_errors On On mail.add_x_header On On mail.force_extra_parameters no value no value mail.log no value no value mail.mixed_lf_and_crlf Off Off max_execution_time 43300 43300 max_file_uploads 20 20 max_input_nesting_level 64 64 max_input_time -1 -1 max_input_vars 10000 10000 max_multipart_body_parts -1 -1 memory_limit 512M 512M open_basedir no value no value output_buffering 64000 64000 output_encoding no value no value output_handler no value no value post_max_size 100M 100M precision 12 12 realpath_cache_size 4096K 4096K realpath_cache_ttl 120 120 register_argc_argv Off Off report_memleaks On On report_zend_debug Off Off request_order no value no value sendmail_from no value no value sendmail_path /bin/sendmail-wrapper.sh c301b78c6c0ce09d736d21c346e7f959ed4e2258 /usr/sbin/sendmail -t -i /bin/sendmail-wrapper.sh c301b78c6c0ce09d736d21c346e7f959ed4e2258 /usr/sbin/sendmail -t -i serialize_precision -1 -1 short_open_tag On On SMTP localhost localhost smtp_port 25 25 sys_temp_dir no value no value syslog.facility LOG_USER LOG_USER syslog.filter raw raw syslog.ident phperr-ugen phperr-ugen unserialize_callback_func no value no value upload_max_filesize 50M 50M upload_tmp_dir no value no value user_dir no value no value user_ini.cache_ttl 300 300 user_ini.filename no value no value variables_order EGPCS EGPCS xmlrpc_error_number 0 0 xmlrpc_errors Off Off zend.assertions 1 1 zend.detect_unicode On On zend.enable_gc On On zend.exception_ignore_args Off Off zend.exception_string_param_max_len 15 15 zend.max_allowed_stack_size 0 0 zend.multibyte Off Off zend.reserved_stack_size 0 0 zend.script_encoding no value no value zend.signal_check Off Off Env:
