Accessing BC OnPrem using an Azure Application Proxy
  • Accessing BC OnPrem using an Azure Application Proxy
    Posted by Chris Warren on February 15, 2023 at 1:59 pm
    As the title states, has anyone done this? I have some remote users that currently use a VPN to access BC, but it would be nice to get this working so they’re not stuck using a VPN client.
    Chris Warren replied 3 years ago 1 Member · 1 Reply
  • 1 Reply
  • Chris Warren
    Moderator
    February 28, 2023 at 11:41 am
    Just in case anyone was following this, you can’t use the Azure Application Proxy to access the BC Web Client on-prem. There are limitations with authentication when logging into the application after it’s configured via AAP.
The discussion ‘Accessing BC OnPrem using an Azure Application Proxy’ is closed to new replies.
